5th Gear Nut Tool
Old Jul 18, 2010 | 12:18 AM
rage_blue's Avatar
The last shop I worked at didn't have a porta power, so every cross member was beat out, then beat back into place, you can beat it back in place but you will have to start the bottom side of the cross member first as its tapered and will help you get the top of it in. But I like lukes idea of bending the tabs in, and I think i would use that if I didn't have access to a porta power.
Old Jul 23, 2010 | 10:11 AM
dvst8r's Avatar
Okay so I managed to round up all the bolts BUT ONE!!!
I am hoping that someone might have one of these in there bolt pile.
It is the metric 10.9 bolt with the 12pt head that holds the tail shaft onto the transmission on an NV4500. I just need one.
Help please.
Old Jul 23, 2010 | 03:23 PM
dvst8r's Avatar
Thanks Rob!!
Time to finally put this thing back together, so I can find my fuel leak, and then maybe build some twins...
Old Jul 23, 2010 | 04:34 PM
Mike Holmen's Avatar
The Guru
I do have a S480 just sitting around in my garage just waiting to be used.
Old Jul 23, 2010 | 04:48 PM
Tate's Avatar
Thats funny, considering its Brett's turbo that I've laid claim to. If you give that away, you better scrounge up that S595.
Old Jul 23, 2010 | 04:57 PM
dvst8r's Avatar
You should scrounge up that S595 anyway, that S480 won't be near enough air for Tate... It will be too much air for me...
Old Jul 23, 2010 | 08:52 PM
The Guru
I can go and get one of those S595, but someone better use it.
As for the S480, first come first get to run. I do have a T-88 collecting dust as well.
I thought that the deal was the first guy that used it owned it.
Old Jul 23, 2010 | 09:04 PM
1-5-3-6-2-4's Avatar
what should I throw on the 12v going my '91?
Old Jul 24, 2010 | 10:30 AM
The Guru
Luke, lots of variables. You want to run twins or a big single? Tate's/Brett's truck have lots of fuel. Tate's will rev till 5000 rpm's and Brett truck seems to have a tons of fuel out of his 215 P pump. We are going to build-up a set of twins that has a smaller secondary than normal and use a larger than normal primary. Of course there are a few Airdrie sunk wurks secerts to get everything to work right.
If no one uses the S480, it goes on my 10 truck No worries, its not like we are going to run out of turbos to choose from anytime soon....
Its just time and beer........
Old Jul 24, 2010 | 11:28 AM
dvst8r's Avatar
I only have a little bit of fuel, Tate has a LOT of fuel.
Speaking of fuel, I found my leak!!! The joiner hard pipe that goes to the return line (about 12" long) had rubbed on something and put a pin hole in it. I welded it up this morning, and just need to let it cool, and it can go back together.
Going to add some sheathing to protect it from happening again.
Now I just need to get the E-brake sorted and it can go back on the road.
Would be nice to have twins on it before I leave for abby at the end of the month, it just doesn't seem very feasible. So a really hot hx-35 will have to do.
Old Jul 24, 2010 | 11:32 AM
The Guru
Luke, can I borrow a manual ISB 12v data/tech book. I'm building up a 12v and there some good factory info in those factory cummins manuals. I have a dodge manual for 01 (its close, but not really).
Anybody have an idea on how much piston to cylinder clearance sled puller use? I know Brett and I have discussed this a few times.
Old Jul 24, 2010 | 11:33 AM
dvst8r's Avatar
Good thread on that here: http://www.competitiondiesel.com/for...ad.php?t=91053
Old Jul 24, 2010 | 11:35 AM
The Guru
Brett, I have enough parts to do the build, I think we could do it. S475 under that 35 would sweet, plus a few tweaks.
or we could go and get a rebuild on that S360 of yours....
Old Jul 24, 2010 | 11:38 AM
The Guru
I was thinking around the 15-20 thou and getting the pistons skirts ceramic/teflon. My 01 dodge book shows a pretty tight piston clearance. I thought the stock pistons was a forged piece.
Old Jul 24, 2010 | 12:37 PM
The Guru
Hey Brett take a look see at this 2002 dodge
http://www.dieselpowermag.com/featur.../photo_02.html
Kinda like what we talked about.
