1500 or 2500 coil springs
i think they had different spring rates. but not just from 2500 to 3500. apparently the trucks could be ordered with a package to be ready for plowing, which was put together with heavier springs up front. so, some trucks have heavy ones, and some have regular springs - regardless of 25/3500, but any truck with the cummins had heavier ones than a gasser would. i can't remember where i came across this info - but i found it a long time ago when researching/shopping for my leveling kit.
i would say going to a company that builds them to your specs is your BEST option. if you decide to just trim some stockers - keep me in mind, i have my stockers which i don't forsee any use for . . .
Thanks Mike...I think 1500 springs from a 4x4 would be the best...Have to find a set..I think 2 wheel spring maybe be to weak...But then I don't know..I think this project will be trial and error..
2wd springs are shorter, and I am betting a lot higher spring rate, since they are about midway of the A-arm, so they will be seeing twice the force, but half the distance during suspension travel. Might want to look into 2500 4x4 coils from a 360 gasser.
Your right Jason...There is a plow option that could be ordered from factory..I don't know if my truck has this option or not,because the tags are missing...Here is something that I also read that I didn't know..The drivers and passengers spring ratings are different for each side..The rating on the drivers is a higher rating..
Thanks Mike...The only springs I have so far is Frednecks front springs of his diesel 4x4..Which I would think,would not give me my 2 inch drop..
http://www.firestoneindustrial.com/r...s/lrinfo.shtml
vtailflyer
Nov 30, 2011 09:41 AM
efab
Aug 18, 2009 03:05 PM
EverydayDiesel
Sep 17, 2007 11:44 PM
