Can I Use Fabtech 1500 Springs On My Ram 2500?
Old Sep 10, 2007 | 02:13 AM
EverydayDiesel's Avatar
Will the fabtech springs made for the 1500 work on my 2500 diesel?
If not ill probably get the spacers but I hate to do that cause they will sag overtime and my springs are completely shot so I might as well get em in one shot.
Old Sep 10, 2007 | 04:15 AM
wcbcruzer's Avatar
They won't work. The Cummins is too heavy. If you use them it might actually be lower in the end. lol...
Old Sep 10, 2007 | 04:34 AM
darn...i guess they just dont make springs for my truck and I have to buy new springs and the spacers.
Thanks
Old Sep 10, 2007 | 04:55 AM
BigTXDually's Avatar
Check this
How much lift are you looking for and is your truck 2 wheel or 4 wheel drive? It makes a BIG difference. If your have a 4x4 i can help you out, and since you live close I can probably help you out a lot. Let me know. Plus how much lift do you want and what size of tires do you want to run??
Old Sep 10, 2007 | 05:25 AM
its a 2wd and im only looking to raise it up in the front around 2 inches
Old Sep 10, 2007 | 07:31 AM
signature600's Avatar
www.coilsprings.com
Call them, tell them what you want, I'll bet they'll build them
Chris
Old Sep 10, 2007 | 07:43 AM
The problem is that no one can tell me what the stock spring height is suppose to be. Its a dealer only item and the dealer has no idea.
Old Sep 10, 2007 | 11:17 PM
Sorry, but being a two wheel drive you are VERY limited on options. i would check out the coil spring web site. If you're looking for a spring measurement you might be able to get an accurate measurement if you jack your truck up and let the spring go to full extension and then add about two inches to that and that will be extremely close to your stock spring length. If i find out something more I will give you a shout.
Old Sep 10, 2007 | 11:31 PM
I called the coil spring people and they want the part number for the left and the right side. Im going to go to the dealership and get those numbers for my truck. Hopefully they can add 2 inches to whatever they find.
Im afraid that after 170k and ORIGINAL shocks ... that my springs have bit the dust and I dont trust measuring the stock height
Old Sep 15, 2007 | 01:12 AM
Philabuster's Avatar
Don at Thuren Fabrication told me he can get springs custom height for the diesels which work with his King shocks and track bar. Give him a call.
www.thurenfabrication.com
Old Sep 17, 2007 | 11:44 PM
Originally Posted by signature600
www.coilsprings.com
Chris
have they made any for you? whats the turn around time on those?
So far Ive almost waited a week.
Donmacky
Feb 1, 2014 06:07 PM
marksblaster
Oct 27, 2012 11:26 AM
Diesel Dave2
ABDTR #5
22
Sep 28, 2010 06:28 PM
efab
Aug 18, 2009 03:05 PM
95turbo4wd
Dec 12, 2007 05:59 PM
