1500 Off road coil springs
Old Mar 25, 2012 | 10:04 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
4X4 1500 Off road coil springs
Has anyone tried this?? Installing 1500 off road coil springs in a 2500 or 3500??
They where installed on the 2000 and 2001 1500 4X4 off road package.I still want to get my front end down while keeping the spring rating close.
I have #39 springs rated at 1688 lbs with a installed height of 12 7/8 inchs (327 MM).
Looking at #23 or #24 rated at 1621 and 1770 lbs with a installed height of 12 1/8 inchs (307 MM).
Not that easy finding a off road package in the wreaking yard..
Maybe able to get new ones..but not sure in I will get my one to 2 inch drop..Maybe the truck will ride/handle worse..
Old Mar 25, 2012 | 12:15 PM
torquefan's Avatar
I've never looked into that. Have you ever looked at the difference between your springs, and those from a V8 or V10 powered 3500?
Old Mar 25, 2012 | 12:17 PM
SIXSLUG's Avatar
There is a dizzying amount of spring options for the 2nd gen rams.
They also use two different spring rates right to left. You may have to experiment and see if they will last. They may sag quickly from the extra weight of the diesel engine.
Can you find a shop to cut a turn off your stock set?
Old Mar 25, 2012 | 12:29 PM
Those should be inthe range of 12 7/8 to 13 inch installed height..Just need that darn one inch drop..
Old Mar 25, 2012 | 12:37 PM
Tell me about...20 different springs for the 94 to 2002 1500,2500 and 3500..I tried the 5 coil spring...That didn't work very well..
I have to stick to the heavier 6 coil spring....I was going to cut half a coil,and depending who you talk to,one says its ok and the next said its a bad idea..Shorter the spring the less give on the spring...May still try it.If it works...great...if not..put the orginals back in and quick mucking around with this aready...
Old Mar 31, 2012 | 10:01 AM
SIXSLUG's Avatar
How about just going to a 14" wheel!!
Old Mar 31, 2012 | 10:13 AM
That would be a real RPM screamer down the highway..
Old Mar 31, 2012 | 01:48 PM
SIXSLUG's Avatar
You'd have to change your sig, too! 95 Dodge, 6.11 rear, blah blah. Probably a lot of trouble.
How about getting a custom set turned by a Southwestern off road shop. May be a little spendy, but could have what you want.
We used to get custom coils for I-beam Fords from E&C Spring in Escondido, CA. They may still be there.
bandit1trucking
Feb 14, 2019 08:16 AM
Phil5981
Sep 27, 2013 10:50 PM
Diesel Dave2
ABDTR #5
22
Sep 28, 2010 06:28 PM
Mule Skinner
Nov 16, 2002 06:57 PM
