4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
Manual trans getting hard to shift.
Old Nov 7, 2011 | 01:55 PM
Nevada's Avatar
Truck has 43K miles and is bone-stock, trans fluid changed at 25K.
Reverse is VERY difficult, 1st & 2nd is pretty tough. Rarely, but occasionally pops out of 5th.
I usually start in 2nd and to get it into gear it seems to get part way into gear with the clutch depressed then jumps in the rest of the way as you release the clutch.
Not hard to get into 3rd thru 6th.
Any ideas?
Could it be a clutch problem?
Old Nov 7, 2011 | 02:16 PM
dieselfreak21's Avatar
Could be the clutch but it usually affects all gear. seems early on the fluid change. Supposed to be at least 100k fluid. Did you get the right fluid? When it was change was there any metal in the fluid? You could try double clutching when you shift if aren't already but shouldn't cause that much a problem. I would suspect something in the tranny is letting go.
Old Nov 10, 2011 | 04:05 PM
Nevada's Avatar
Took it to the dealer. The problem is with the dual-mass flywheel. With the engine off and the clutch depressed you can run through all of the gears easily. Start the motor and it became very difficult to get into gear. They originally diagnosed it as a clutch problem but after opening it up determined that the problem was the flywheel. In any case I end up with a new clutch apparently.
Old Nov 10, 2011 | 07:38 PM
Blake Clark's Avatar
Good to know.
My Dual mass is getting scrapped in December
Wulfdiesel
Sep 19, 2013 10:55 PM
Dave7060
0
Feb 13, 2012 05:03 PM
SuperDutyDave
Oct 27, 2009 07:39 PM
1ghunt
Mar 29, 2007 01:57 PM
Bio
Sep 15, 2005 07:07 PM
