4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
High idle
Old Dec 8, 2011 | 09:20 AM
DieselBoy20's Avatar
High idle
Will keeping my truck on high idle all the time while idling at all help to keep my dpf from plugging up? I run equipment in Alberta and it's winter and cold and I need to be able to run this truck and idle about 1 hour in the morning and 1 at night?
Old Dec 8, 2011 | 09:22 AM
The truck is a 2012 srw mega cab with about 2000kms so far, I'm new to the fourth gens
Old Dec 9, 2011 | 02:34 PM
Bump?
Old Dec 9, 2011 | 02:35 PM
What are the temperature limits for the new 6 speed automatic also?
Old Dec 9, 2011 | 04:12 PM
Blake Clark's Avatar
Idleing for an hour or so wont hurt much if you have a good run with it later.
Not sure on the temp limits, but Id say anything over 230 or so Id get worried.
Old Dec 21, 2011 | 12:27 PM
Busboy's Avatar
My son rolled into town late last night dragging a cargo trailer, because the roads were icy from the freezing rain and snow he was down to 30MPH for the last 8 hours. His check engine light has been on for weeks but he was in a remote location, he's at the dealer now and they say the DPF is plugged. He idles his truck lots and even with a fast idle installed by the dealer on his 2011 G56 truck it will not maintain the heat during extremely cold temps. He's going to ask the dealer to throw the new DPF in the back of the truck and just say they installed it. We've got "the stuff", H&S mini, egr/cooler, and stage 2 intake, not to forget the most important part, the hunk of exhaust pipe to replace those two horrible pieces. I'm hoping this will cure his problems, if not at least he will get better fuel economy but he doesn't pay for fuel, and if this doesn't solve his problems there is always an Espar heater.
Old Dec 21, 2011 | 03:01 PM
Hey Busboy, got any more info on the G56 fast idle?
Old Dec 22, 2011 | 10:05 AM
Busboy's Avatar
We are finishing the full deletes today so if there is anything specific let me know. Basically there are 2, 2 position switches mounted on the control column, one for each speed 1200rpm and 1500rpm. I haven't followed the wires to see where they go but it looks simple. When he bought the truck in the spring there wasn't one available but it was being developed. He had to come back to the city because the check engine light was on and it was then when the dealer installed it. I haven't seen the truck since it was installed until yesterday and we were kind of busy. There is so much stuff in his truck it's not even funny. 2 Navs, 2 bluetooths (only the aftermarket bluetooth works) VHF com, radar detector, Ipod, cell charger and phone holder, remote charging points for the other guys, roof top light, there are so many wires it's hard to see out the front window. We did dash mount the mini max to clean things up a little though.
Old Dec 24, 2011 | 10:55 AM
Ya I'm doing a full delete, this truck is horrible on fuel and I can't wait to know the truck is running 100% after the deletes
Old Dec 24, 2011 | 11:23 AM
Busboy's Avatar
I don't know if you are replacing the factory intake manifold but when we removed my sons I just couldn't believe what I saw, the intake on the engine was very clogged with carbon and so was the manifold, there was raw fuel running down the inside of the boost pipe. It definitely shocked me. I snapped a couple of pics that are awaiting approval and will post them.
Old Dec 24, 2011 | 09:35 PM
JCMINIS's Avatar
Dealer told me it couldnt be done on mine, no provisions in the ecm like the pre 10 models. So I mounted my XRT pro and control it with that ! 700-1500 rpm I think is the range.
Old Dec 26, 2011 | 11:14 AM
Busboy's Avatar
The dealer also told my son it couldn't be done when he bought the truck in March/April they also told him something was in the works. I agree that using a programmer for the fast idle is a lot better as the two switches are not very "esthetically pleasing" ( they look like c***) but his is a work truck.
Old Dec 26, 2011 | 04:45 PM
Yeah, just found out the XRT Pro does the high idled if left plugged in.
Thanks fellas
Old Dec 26, 2011 | 07:41 PM
Busboy's Avatar
Thanks fellas
I'm pretty sure the mini max does also.
Old Dec 26, 2011 | 10:33 PM
JCMINIS's Avatar
The only prob with the xrt pro is if its plugged in, its on. I rigged mine so it could be left plugged in to the obd port. At night or when I dont need it I just pop it off the mount(bottom pic) and put in console. Nothing holds the xrt to the mount other than the cable plug.
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
dieselnewbie
Jan 18, 2005 10:48 PM
