truck wont turn over
2011 5500
Just got truck out of the shop.had a new motor put in
drove truck home about 60 milew no problems
Go out side to move truck about 30 mins later
wont turn over. All lights everything work
need help james
need help james
Cummins Guru
Check battery connections make sure they are all tight, check battery volts, pull cover on PDC make sure all relays are pushed in, check starter relay does it click when turning key to start. Check fuse #7 it will be 40 amp fuse in the PDC, check the yellow and gray wire make sure it is plugged in to starter motor
Read TSB also may apply to your problem or just remove fuse M27 and reinserting back after a few minutes.
