4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
new 5500 dump ready to work
Old May 19, 2008 | 09:54 PM
lilsuzuki4x4's Avatar
Originally Posted by bmgcat
Sweet looking setup!!! I believe your trailer might be a tad bit over loaded though? Also, with all that tongue weight and your rear axle almost centered underneath the dump body, I wonder how much you can really haul in the bed. Its sure nice to see the rear axles set back on trucks so the front axle handles part of the load too................since they started putting the fuel cells all the way to the rear, it really screwed things up. IMO. Bad looking truck though!! Im so jealous.........
thanks!! I love my new set-up!! The trailer has 2 7000 lbs so I am good for ~12000 LBS my mini bobcat (463) is 2700 lbs and my S-205 is 6655 lbs so round it up to 10000 lbs only. I can haul 1/2 load when pulling machine's (something that I never do anyway)
Old May 19, 2008 | 10:07 PM
bmgcat's Avatar
Ahhh, i thought it was an S250 on the rear of the trailer. My mistake! Happy trailering!!!
Old May 24, 2008 | 12:34 AM
No prob!! I wish it was a big S250 sometimes but for the most part I love My S205, it has super float tires and has less ground pressure that my mini!!
Old Jun 2, 2008 | 11:49 PM
Colo_River_Ram's Avatar
With age comes the cage
Originally Posted by lilsuzuki4x4
The box spec’s says 5.6 yards, and the electric over hydraulic pump is good for 5 ton. I hauled 5-6 yards of top soil no problem. The truck is good for 19500 minus truck weight of 8500 (I think without looking at spec’s) and minus 1750 for dump box and some for fuel and trailer hitch. The truck should be able to haul 9000 lbs, but we have road bans out now so you can only haul 75% of GVWR.
So finally to answer your question (not that I have a definite answer) you would have to find out how much is 1 yard of gravel is and go from there, but I would guess gravel is more than topsoil.
You said elec/hydraulic pump what brand did you go with?
I am thinking either a PTO mount to the 6 spd Aisin on the 5500 bullet or an engine mount with clutch cut out as I want to run front-rear winches, welder and an air compressor with my system..
Old Jun 7, 2008 | 01:26 AM
the pump is a monarch,
http://www.monarchhyd.com/
Old Jun 8, 2008 | 11:19 PM
Thanks for the info!
djdc
Jan 22, 2010 05:53 AM
1st gen wontabe
Jan 18, 2010 08:25 PM
brett3
21
Aug 20, 2008 06:25 PM
deere nut
34
Sep 28, 2007 08:25 PM
JTCHess
Feb 21, 2007 05:20 PM
