new 5500 dump ready to work
I rigged up this truck myself with help of a few good friends, 2008 Dodge 5500 Laramie Quad Cab with crysteel 11' dump with fold down sides, still need tool boxes and a few things, but have to work.. I will add on when I have rain-out days!!
Cummings610 did you fuel mileage improve any? I am not even going to worry about untill I get at least 35000-40000 km's on it!!
So finally to answer your question (not that I have a definite answer) you would have to find out how much is 1 yard of gravel is and go from there, but I would guess gravel is more than topsoil.
The box spec’s says 5.6 yards, and the electric over hydraulic pump is good for 5 ton. I hauled 5-6 yards of top soil no problem. The truck is good for 19500 minus truck weight of 8500 (I think without looking at spec’s) and minus 1750 for dump box and some for fuel and trailer hitch. The truck should be able to haul 9000 lbs, but we have road bans out now so you can only haul 75% of GVWR.
Nick
The road ban here, is in spring time, the roads are soft from ground thawing, so you can only haul 75% of your max load from March to June. So for easy #'s if you were able to haul 10000 LBS you can only haul 7500 during road ban.
Sweet looking setup!!! I believe your trailer might be a tad bit over loaded though? Also, with all that tongue weight and your rear axle almost centered underneath the dump body, I wonder how much you can really haul in the bed. Its sure nice to see the rear axles set back on trucks so the front axle handles part of the load too................since they started putting the fuel cells all the way to the rear, it really screwed things up. IMO. Bad looking truck though!! Im so jealous.........
