4500 / 5500 - Chassis Cab Trucks Talk about your commercial trucks here. We realize there are differences with these compared to the regular pickups, so we have provided a place to discuss the commercial versions only.
High Idle switch..
Old Feb 26, 2008 | 10:40 PM
07Chassis's Avatar
High Idle switch..
Both of my 07 cab and chassis models don't have cruise control. I know some of the powerstroke guys make a high idle switch from some of the existing pto wiring which is unused. I have a pto wiring harness that came with upfitters package. Is it possible to use this to allow high idle of lets say 1,000-1,200rpm? I was doing some looking around and I know the guys with cruise control have no issues (just need to activate ability to use cruise to raise idle), but alot of the c&c guys don't have cruise.
Old Feb 27, 2008 | 07:22 PM
w.tx iceman's Avatar
You can buy the cruise switches for 46 bucks and you will have cruise, then get the high idle enabled and your set. This is what I did on my 05
Old Feb 27, 2008 | 09:00 PM
07Chassis's Avatar
46 bucks for cruise control? thats crazy. Is the wiring in the wheel already?
Old Feb 27, 2008 | 09:04 PM
07Chassis's Avatar
Just found a post on tdr..here it is..
Here is a brief description of how to install cruise control for your Dodge Ram ST.
1: Purchase these switches at your friendly Dodge dealer.
RIGHT HAND SWITCH #56049378AB-RETAIL $18.79
LEFT HAND SWITCH #56049379AB-RETAIL $19.91
2: In order to remove the airbag from the steering wheel, you need to turn the steering wheel 90° from center. This will let you access the two bolts on the back of the steering wheel. (I used a deep socket 10mm 1/4" drive ratchet)
3: Once the steering wheel is placed at the 90° position, shutdown the engine and remove the two negative battery cables and wait a minimum of ten minutes for the airbag module to be drained of available power.
4: Now remove the airbag by removing the two bolts at rear of the steering wheel. Have someone hold the airbag while you remove the switch blanks, this permits you to leave the airbag wiring connected.
5: The switch blanks are removed with a Phillips screwdriver, when these are removed just install the new switches and put everything back together and enjoy your cruise control equipped Ram!
This procedure is confirmed to have worked with the following model year trucks.
04.5 manual trans, and an 06 auto equipped truck, I feel that the price of the switches are worth it just to see if it will work on your truck. I'm willing to bet that it does!
kicker210
Dec 2, 2009 08:23 AM
dahla
14
Jan 16, 2009 03:27 PM
caper
Oct 16, 2007 10:00 PM
jmccart
Jun 12, 2007 02:12 PM
ratat98
14
Mar 19, 2006 02:08 PM
