Weep Hole inspection
Old Sep 2, 2004 | 06:42 PM
TurboTed's Avatar
I printed off instructions from a post on our site a while back on how to check the water pump weep hole for blockage. It shows a pencil either pointing at or with the tip in the weep hole('03). It says to look at the weep hole with your "Nose above the O in the Caution Fan warning." I have no problem seeing the location, etc. But- even when I use a trouble light, flashlight, try different angles of view, etc. I can't see the "hole". There's the rad hose from above, the belts from the side, etc... Maybe I'm just looking at it wrong, or have to take off the rad hose, or am I just crazy! What am I doing wrong??
Old Sep 2, 2004 | 07:51 PM
Grey Rider's Avatar
What makes you suspect a blocked weep hole? And what's so bad if it is blocked?
Old Sep 2, 2004 | 09:30 PM
TurboTed's Avatar
Nothing makes me suspect it. However, as part of your regular maintenance schedule (along with oil changes, air filter inspection,...) your manual says to check it. What would happen if the weep hole has blockage...I'm not sure.
Old Sep 2, 2004 | 11:42 PM
Jeff in TD's Avatar
I think mainly you are supposed to look for signs of coolant- hopefully to catch a failing water pump before it dumps on you on the side of the road.
Old Sep 3, 2004 | 06:36 AM
sawboywv1's Avatar
I've looked hi and low and can't find it either?
Old Sep 3, 2004 | 11:44 AM
cquestad's Avatar
You can't find the hole most of the time till it starts spewing coolant. Don't worry about it...
Old Sep 3, 2004 | 12:47 PM
Miles PH's Avatar
Don't worry be Happy it's not leaking. But relay do keep a eyeball on once in will so you don't get left on side of the rode.
Old Sep 3, 2004 | 01:28 PM
TurboTed's Avatar
Thanks guys! If it's leaking, apparently it'll be more than just a little dampness. Now I know what to look for!
gorms
Jun 14, 2011 04:20 PM
stealman1
Sep 15, 2008 07:15 PM
Dojman
Jul 30, 2005 04:48 PM
Haulin_in_Dixie
Sep 14, 2003 02:24 AM
DODGE4X4
Aug 29, 2003 11:12 AM
