Water Pump Weep Hole
Old Sep 13, 2003 | 03:38 PM
Haulin_in_Dixie's Avatar
Several times in the past there has been a thread where the CTD owner could not find the weep hole on his water pump. I never saw anyone respond to this problem. The weep hole on mine was on the driver’s side of the pump and I assumed that all of them were the same. I recently changed my water pump and there has been a change that has caused this confusion. The weep hole on the new pump is actually a depression in the casting where the flange bolts to the block. Unless knowing it is there it would probably be missed as it is not a hole in the pump, but rather a channel cast into the flange. It exits the bottom of the pump, against the block.
Old Sep 13, 2003 | 10:16 PM
DODGE4X4's Avatar
Re:Water Pump Weep Hole
That must be were mine is b/c I gave up looking for it. So which bolt is it by and is it necessary to clean it ??
Old Sep 14, 2003 | 02:24 AM
Just look on the bottom of the flange just about in the center of the pump, not sure how it indexes with the bottom bolt. You might clean it with a piece of baling wire, the vent is not as large as the almost 1/4 hole in my original one.
edtyler
Sep 7, 2011 07:02 PM
stealman1
Sep 15, 2008 07:15 PM
Dojman
Jul 30, 2005 04:48 PM
TurboTed
Sep 3, 2004 01:28 PM
DODGE4X4
Aug 29, 2003 11:12 AM
