Upgraded steering
Old Jan 7, 2009 | 02:12 PM
  #196
John_P's Avatar
Originally Posted by MassZJ
I just read all these posts but couldnt find the actual TSB number? Can someone post this. I have a few trucks that are going in for service and would like to have this performed. One guy has already complined about the death wobble while towing.
MassZJ:
Here is the information/number etc. on the TSB for this problem. It was posted back on Page #2 (Post #16) by DTR Member "Bronco Hound."
__________________________________________________ _________
STEERING WOBBLE/VIBRATION ON 2003-2007DODGE RAM TRUCKS 2500/3500)
TSB #22-005-06
Models:
2003-2007 (DR/DH/D1/DC) Ram Truck (2500/3500)
NOTE: This bulletin applies to four wheel drive (4x4) 2500 and 3500 model vehicles.
Symptom/Condition:
The customer may experience a self sustaining vibration (shimmy) felt in the front end of the vehicle after striking a bump or pothole.
Parts Required:
52106909AE--Damper, Steering
05086146AC--End Package, Tie Rod Outer
05086144AC--End Package, Tie Rod and Link Outer
06505623AA--Nut and Washer, Tie Rod
John_P
Old Jan 7, 2009 | 02:25 PM
  #197
MassZJ's Avatar
Thanks John. Not sure how I missed it.
Old Jan 7, 2009 | 02:30 PM
  #198
John_P's Avatar
You are very welcome on the link. And not to worry, I miss stuff all the time on here myself. It is harder when the threads are real long like this one too.
John_P
Old Jan 8, 2009 | 06:28 AM
  #199
stroker101's Avatar
it would have been nice if Dodge would have someone engineer zerk fittings into this new and improved steering system
Originally Posted by mitternocht
Here is the new steering setup:
Old Jan 8, 2009 | 05:53 PM
  #200
wiskeyVI's Avatar
Wasn't there antoher thread awhole back where somebody drilled and tapped thier own zerks into this or somthin like it??
Old Jan 8, 2009 | 10:11 PM
  #201
ajpulley's Avatar
Ya, I wish they had them too. Now, the only thing on the truck to grease is the cordon joint on the front drive shaft.
My Jeep has the original ball joints and tie-rod/drag-link end joints. They've always been greased every 3K... and I'm still greasing them.
Old Jan 9, 2009 | 02:26 PM
  #202
TX_Diesel's Avatar
As stated above, I don't see why you couldnt' just drill and tap your own zerk fitting...
Old Jan 9, 2009 | 04:00 PM
  #203
xtoyz17's Avatar
Since they're sealed, they're greased. Not only do you run the risk of drilling to deep and damaging the actual ball joint, you'll never get the metal shavings out. You'll ruin the tie rod ends faster with a damaged joint and metal shavings than you would if you never had the ability to grease the joints to begin with.
That's just my .02 though, your mileage may vary
Old Jan 9, 2009 | 04:28 PM
  #204
ajpulley's Avatar
Ya, I agree... which is why I wish they came already installed, or designed and made that way. I'm not going to hack them in on this truck. I've got the Jeep for that.
Old Jan 10, 2009 | 02:43 PM
  #205
Mr Jerry's Avatar
Re-creation
Originally Posted by vcoyle
Need some help on this.... I have never experienced the death wobble (and prefer not to) so I took my truck to the dealership today and told them about the TSB to fix and that I had the death wobble once. Dealership's reply is that he has never heard of the death wobble on a Dodge, only on Wranglers so he wants to see if he can make it happen again. Stupid me forgets to ask him exactly how he is going to recreate this. I know we are a little slow down here in Alabama, but isn't this death wobble a common issue? I've seen it happen to someone else and prefer not to experience. I'm just trying to figure out how he will recreate and why on my truck. Any advice would be appreciated.
Did you see that dirt bike trail out behind the dealership? Need I say more.
Old Jan 11, 2009 | 09:58 AM
  #206
Dan_K's Avatar
So I've been driving mine for about a week now, and see little to no improvement with the wander on the road.
They put a new steering gearbox in as well, and I made a complaint with Dodge customer service as this is the 3rd gearbox (2 on my 05 in 70k miles, and 1 on my 07 in 24k miles) They documented my complaint and it should be warrantied should I have a problem again after my 36k warranty is out. If I jack the front tires off the ground, I can grab the driver tire, and rock it just slightly from top to bottom. The pass side is tight, so I'll have to take it back and have them replace whatever is causing this. Hopefully this will cure the wandering.
Old Jan 11, 2009 | 05:57 PM
  #207
xtoyz17's Avatar
That's a ball joint or wheel bearing. Either would cause wandering for sure.
Shawn
Old Jan 11, 2009 | 08:53 PM
  #208
RTA Cattle's Avatar
Well, I just got my upgraded steering installed this afternoon and all I can say is WOW!! All of the slop in the steering is gone, I also put in a new gear box. The truck drives like new agian, well pleased with the results. Glad I found this thread.
Old Jan 12, 2009 | 10:25 AM
  #209
az0091's Avatar
I have Toyo MTs mounted on stock wheels and it pulled to the right. The dealership here in Mexico installed this on Friday and so far I have not felt the truck pulling to the right. I also had them balance & rotate my tires using an X pattern, maybe that also helped.
Old Jan 14, 2009 | 01:17 PM
  #210
MeanGrn's Avatar
so will this new 08 set up work on a 2000 truck, i read most posts but cant find that info, the dealers say it will not work but i have heard that some people have used the 98-99 set up which was very similar to this, anyone know for sure on this? i am trying to eliminate this light duty steering i have and this would be a great fix
