Transfercase shifter question
Old Aug 10, 2006 | 04:10 PM
jpfishmaster's Avatar
In my new search for an 03-04 CTD I have noticed that both 03 and 04 models have had the transfercase shifter in the floor. One 04 had it in the floor and another with the switch **** on the dash. Is the traditional shifter standard or an option? Thanks>
Old Aug 10, 2006 | 04:28 PM
Stormin's Avatar
Standard. In my opinion it is the best way to go. The shift on the fly method goes out too often and too much can happen to it. All you have to do is ask someone who wheels alot and they will tell you.
Old Aug 10, 2006 | 05:19 PM
bubba33's Avatar
I would take either one that would not make any differance to me.
Old Aug 11, 2006 | 02:41 PM
SOhappy's Avatar
I believe the **** was only available in the Laramie trim. Having owned several chebbies with "the ****", and nothing but trouble, I was grateful that mine came with a floor shifter. I trust a mechanical linkage over an electrical circuit anyday for redundancy IMHO.
Old Aug 11, 2006 | 03:35 PM
bamataco1's Avatar
Yea give me the shifter on the floor every time. It's a tried and true system.
Old Aug 11, 2006 | 04:46 PM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
I have heard of only one guy on all sites complain about a switch not working properly . It works good and there is very little trouble with it . I have put mine in and out of 4x4 40 times in one day and never one glitch . The clean floor space is nice and I like the extra room , there is nothing wrong with this set up . I have always had the floor before this and this works smoother and faster with less trouble . I was skeptical myself before I got my truck with a lot of guys spreading wrong information on the electric shift . A Chevy , Ford or whatever set up gave me trouble does not make this one junk . I had problems with all my Ford power windows should I avoid Dodge power windows ?
Old Aug 11, 2006 | 05:00 PM
elirandolph's Avatar
I have the **** on the dash and I love it!! no problems. I have also heard that lever on the floor is still electronic, you just activate it by moving a shifter rather than turning a ****.
Old Aug 11, 2006 | 07:14 PM
Thanks for the input> It's all gonna come down to just the right truck. Thanks again.
Old Aug 11, 2006 | 07:20 PM
Deesil's Avatar
Muted User
No, the floor shifter is not electronic, not even close
Old Aug 11, 2006 | 09:29 PM
sinton's Avatar
Doesn't feel electronic when I throw it in 4WD.
Old Aug 12, 2006 | 10:59 AM
Thenewguy's Avatar
The floor shifter is directly connected to the transfer case. The only problem I could see that might be trouble is if you go off road and a rock bends the rod from the bottom of the shifter to the t case.
Old Aug 12, 2006 | 12:03 PM
tkerrigan's Avatar
As long as we are talking about elec transfer case shifter, mine has a neutral position on the switch, but you can't turn it there. Is there a trick I don't know about, or did they just put a neutral position on the switch just to confuse me? High, high 4wd, and low 4wd work fine.
Old Aug 12, 2006 | 12:55 PM
pet05's Avatar
There is NOTHING wrong with the electronie one. There are so many electronic parts on these trucks, that if people are worried about an electronic shifter versus a manual, they have no idea how many electronic control devices are in their trucks.
I believe the electronic shift is the LEAST of the worries.
I like the clean looks of the electronic one, it gives you more space on the floor, it will actually NOT grind like the manual one does because it is computer controlled.
Old Aug 12, 2006 | 01:17 PM
cromulius's Avatar
I've had both and like the manual floor lever much better. I use the 4 low at the local land fill once a week on average.
Old Aug 12, 2006 | 03:28 PM
I have had a few problems with the manual over the years , usually wearing out the linkage and having a hard time going into 4 low but over all they fail very little . I grind less with the electronic and it just goes in easier for me and I use it a lot . What it will do 10 years down the road who knows but for now I like it . When I bought the truck I wanted the manual shift because of all the false rumors I had heard . I did a lot of searching and only found one failure on a brand new truck that never got plugged in underneath at the factory . I may be cussing it down the road but right now I would order another truck just the same way . I was told if it failed I could climb under neath and do it manually . Not something I want to find out in the mud and it would lead to the cussing but could save my but some time .
that_guy
Jan 4, 2011 11:14 AM
smokinram99
26
Feb 13, 2008 09:05 PM
01deezy87
Jan 19, 2008 09:28 PM
J_T
Sep 4, 2007 10:27 PM
Dieseldirt
Oct 3, 2006 07:16 AM
