How hard to remove the Transfercase Shifter?
Old Sep 3, 2007 | 09:49 PM
J_T's Avatar
J_T
How hard to remove the Transfercase Shifter while the transfercase is still in the truck? I removed the body lift and due to the 3" extension added to the shifter it hits the dash in 2wd. I can cut it out but I don't want to reweld it while its still IN the truck!
Thanks in advance!
JT
Old Sep 3, 2007 | 10:13 PM
ChargerLighting's Avatar
I think there's (3) 9/16" bolts, a linkage rod that has to be popped off & then it will come down. You have to unscrew the **** so the shifter will go down through the boot.
Old Sep 4, 2007 | 02:24 AM
ScottN's Avatar
2 bolts on the shifter to the tranny, and you pop the rod out of the bottom of the shifter. Hardest part will be getting the **** off the passenger compartment side of the rod.
Old Sep 4, 2007 | 10:27 PM
dieseldemon's Avatar
Remove the dacal from the **** with a small screwdriver then with a 15mm socket remove the nut that holds the **** then remove thr **** go under the truck and pry the shift rod loose from the shifter then remove the two bolts from the side of the shifter 5/8 socket it will fall out the bottom.
crossy
Oct 2, 2013 07:00 PM
90 power ram
Apr 18, 2011 02:47 PM
Dieseldirt
Oct 3, 2006 07:16 AM
jpfishmaster
14
Aug 12, 2006 03:28 PM
Dodgezilla
Jul 17, 2004 05:24 AM
