Sirius Problems
Sirius Problems
I have a lifetime subscription to sirius and it stopped working the other day.It does not show " no signal " It is stuck on ch.184 and I cant change it. It also does not play anything,no volume.It was originally stuck on ch.6 I then unplugged the power to it and it went to 184. I called sirius and they said the signal is being sent. Anybody help me out with this. Thanks
As far as I know, if you can receive channel 184 your receiver is working and its an issue on their end. However the no volume thing is strange. If possible try to swap the unit out with a buddies to make sure that its working properly.
Not sure how much a replacement tuner from Dodge is, but Id be willing to bet its more expensive than a decent aftermarket radio and tuner.
Had the same issue with the no volume and channel 184 on my '06. Went online with Sirius and had them send a reactivation signal and it has worked since. Your radio has to be on channel 184 and receiving a clear signal to be reactivated (ie: can't be parked in the garage). I would leave it on for a half hour or so. Then check to see if you can change channels.
Good luck
Good luck
Sirius tried to reactivate the sysytem,however,it was stuck on Ch. 6 at the time.I then pulled the power from the unit and it defaulted back to Ch. 184.I will call sirius again now and try reactivating on 184.Thanks
First they replaced the head unit, didn't do a thing...exact same issue with the new head unit.
They then replaced the satellite tuner, that did the trick.
Here's the thread:
https://www.dieseltruckresource.com/....html?t=241943
UTBoatFanatic
17
Mar 11, 2011 06:28 AM
hovisimo
Mar 21, 2005 04:38 PM
