Roaring when brakes pushed
Old Apr 20, 2011 | 06:50 AM
Undertaker's Avatar
I have a 2007 DRW Dodge. I just had work done at a local shop. I needed a new u joint up front, new wheel bearing up front, and caliper cleaned because I guess it was causing pads to drag on rotor. Since I have got it back I get an occasional knocking sensation, roaring when I apply the brakes at highway speed, and a shutter from brakes when about to stop it shakes the whole truck.
Old Apr 20, 2011 | 07:40 AM
Nate-03 D's Avatar
Any chance that the rotors are warped?
Old Apr 20, 2011 | 08:01 AM
Undertaker's Avatar
No the rotors aren't warped. Someone else told me they thought it was a abs speed sensor, but my abs light isnt on.
Old Apr 20, 2011 | 09:04 AM
Nate-03 D's Avatar
hmm, not sure how the ABS sensor would cause the truck to shake. It shouldn't even cause a noise, if it was pushed to far out against the exciter wheel it would push back in once you started moving.
What U-joint was replaced on the front? The caliper could still be hanging up. Could you jack up the side that had the work done and spin the wheel?
Old Apr 20, 2011 | 09:17 AM
Undertaker's Avatar
I'm not sure. I know to change it though they had to destroy the wheel bearing to get to it because it was seized on. Either way I'm not happy about the situation
Old Apr 20, 2011 | 09:22 AM
Nate-03 D's Avatar
It may be worthwhile taking it back in and having them look over what they did, then again maybe it wouldn't. They might of destroyed something else in the process of taking out the bearing.
Old Apr 20, 2011 | 09:48 AM
whiteeye42's Avatar
i did not know you could just change out the wheel bearings i thought you had to get the whole hub assembly which comes with everything in one unit
Old Apr 20, 2011 | 09:53 AM
1-2-3's Avatar
Just a plain ole guy
That's why they had to beat it apart. Those are all sealed and pressed together and aren't intended to be pieced back like that. My bet would be they beat your hub all up.
Old May 9, 2011 | 11:46 AM
thenrie's Avatar
I haven't had to change my bearings yet, but looking at the parts diagram, they appear to be just sealed bearings pressed into the hub. A garage with the right tools should be able to simply press them out and press in new ones. Maybe not. Like I said, I haven't yet tried to order them. I think I'd be looking for a new garage, myself.
As for cleaning a caliper that was not functioning properly, it would probably have been cheaper to buy a new (remanufactured) one from Autozone than to pay for the labor to have them clean the old one. Mechanics are getting $80-90/hr now.
Stike two. I would definitely be looking for a new garage.
98ramcummmins
17
Mar 23, 2009 01:48 AM
Boz007
Mar 1, 2007 06:42 PM
12vordie
Jun 22, 2005 11:39 PM
1ST GEN.
Oct 12, 2004 09:20 PM
KenR
17
Feb 12, 2003 06:23 PM
