Roaring 4th
Old Oct 5, 2004 | 05:24 PM
1ST GEN.'s Avatar
Roaring 4th
I HAVE A 99 3500 WITH AN NV4500 AND WHEN I GET A STRAIN ON IT IN FOURTH IT ROARS PRETTY BAD BUT IT DIDN'T DO IT UNTIL THE EDGE COMP AND THE DD3'S AND 5TH GEAR IS JUST FINE. WHAT IS THE PROBLEM
Old Oct 6, 2004 | 11:00 PM
KATOOM's Avatar
Call Standard Transmission.
Old Oct 11, 2004 | 08:51 AM
duner's Avatar
sure it's not the fan your hearing?
Old Oct 11, 2004 | 10:15 AM
nitrousn's Avatar
sounds like the fan kicking in due to heat build up. i hope you have a pyrometer probbed before the turbo.
Old Oct 12, 2004 | 09:05 PM
rich's Avatar
sounds like your stripping the input shaft gears on the tranny. i've done it 3 times so far.
Old Oct 12, 2004 | 09:20 PM
1ST GEN.'s Avatar
THE TRUCK STILL DRIVES AND SHIFTS FINE IT JUST ROARS ONLY IN FORTH, IT SOUNDS LIKE MY 92 DODGE WITH THE GETRAG 5 SPEED WHICH GROWLS IN FIFTH BECAUSE THE FRONT INPUT SHAFT BEARING IS WORN SO COULD IT BE A BAD BEARING OR JUST THE INPUT SHAFT
DUKFVR
Dec 8, 2008 05:18 PM
Mega07
Jul 19, 2007 12:37 PM
Boz007
Mar 1, 2007 06:42 PM
12vordie
Jun 22, 2005 11:39 PM
KenR
17
Feb 12, 2003 06:23 PM
