Question About Howling or Roaring Noise
Old Dec 8, 2008 | 10:23 AM
DUKFVR's Avatar
The truck in my signature is it. At about 70 mph or so I seem to get a howling or roaring noise in the truck. No vibration that I can feel or notice. Seems to be right under the cab or so. May be a little louder pulling a trailer or climbing a hill while accelerating. . Diff Fluids have been changed & lift is not much more if any in the rear. Going below 70 really not noticeable. Is this normal ? Wondering if an out of shimmed carrier bearing could do this. Any help that can be sent out would be GREATLY Appreciated.
Old Dec 8, 2008 | 01:51 PM
dozer12216's Avatar
Drive line at that speed would beat your ears because of high frequency. The center bearing alignment could be a issue if you raised the unit(unclear) some. Inspect shafts for damage and worn U-joints. Will it coast through in neutral???????
Old Dec 8, 2008 | 02:36 PM
DUKFVR's Avatar
It has a leveling kit on the front, back had a different spring pack put on ,but didn't raise the rear much at all if any.
Stupid ? ,but what do you mean coast thru in neutral? Its really hard gfor me to desribe the noise, more of a roar [almost like a loud exhaust] than a howl. All the shafts & joints look & feel fine.
Old Dec 8, 2008 | 05:18 PM
ColdCase's Avatar
So like roll up the window...
Sounds like a worn driveshaft U joint to me. I had one go that sounded about like that. You'll have to take a close look at the drive shaft to determine which one. I actually had two go at the same time.
jlandry
Jan 1, 2011 05:45 PM
leftturn7m
Aug 22, 2009 10:20 PM
sjester
Jan 9, 2009 11:07 PM
BLKHO600
Mar 21, 2005 11:28 AM
KenR
17
Feb 12, 2003 06:23 PM
