20-30mph howling/buzzing noise
Old Mar 1, 2005 | 09:09 PM
BLKHO600's Avatar
Ok took my truck to the dealer about this low speed 20-30mph howling/buzzing noise. Happens either with or without load. Most noticeable when coming to a stop. Pretty annoying. I know someone in here once mentioned that it was the "DRIVESHAFT BEARING" or something of that nature. Does anyone know exactly what this piece is called. Reason why it makes it is because it gets worn out prematurely. And I remember that person said it should be fixed because it can cause more future problems. Can anyone forward me to that post. I couldn't find it. Thxs so much!!!!
Old Mar 1, 2005 | 09:12 PM
BLKHO600's Avatar
Also are these driveshaft bearings on a NATIONAL BACKORDER. Someone told me that from the dealership.... I am confused!!! Please help!!!
Old Mar 2, 2005 | 12:11 PM
BLKHO600's Avatar
help please!!!!
Old Mar 2, 2005 | 12:46 PM
tdupuis's Avatar
From: New York City / Terre Haute, IN / San Antonio, TX
I get a differential howl when the diff is cold in the 20-30 mph speeds. Once the thing warms up, the noise goes away. As such, I ignore it. I haven't heard anything about driveshaft bearings going bad. Also, you don't list any of the specifications of your truck. That doesn't give us much to go on. And if you don't get a response in 12 hours, just wait a little longer. Responses aren't always instant.
Is the howl at all times or only when cold? Also, do you drive your truck for more than 5 miles at a time? It takes my truck probably about 15 or so before it will actually stop howling.
Good luck.
Old Mar 2, 2005 | 02:44 PM
BLKHO600's Avatar
Good luck.
mine is a 3500 drw qc 6spd. my howling happens at 20-30mph all the time.... i swear someone in here had something replaced and it fixed it. he went on to say that if any of us have a similar problem he could fax/post his receipt so we can show the dealerships that are in denial. CaN THIS GUY PLEASE STEP UP.. really need help!!!
I think the Dealership is BSing me.... help
Old Mar 5, 2005 | 03:40 PM
JRTRU's Avatar
My truck has the same thing going on,Once the thing warms up, the noise goes away.
Old Mar 6, 2005 | 08:05 AM
kry226's Avatar
I think it's a howl from a cold turbo. Mine did this yesterday when I started the truck and turned on the high idle. Same howl as when I would just start up and drive 20-30 mph cold.
Old Mar 18, 2005 | 01:57 PM
guidster's Avatar
It sounds like a hoot owl at about 20 mph when under 50 degrees and I am quite sure that it is the rear carrier bearing transmitting resonance through to the chassis as it does not sound like a rear differential problem. I plan on taking mine in next week to try and get it fixed--will let you know the outcome.
Old Mar 18, 2005 | 07:14 PM
Tiara3100's Avatar
Here is an older post on this topic:
https://www.dieseltruckresource.com/...threadid=56572
Old Mar 18, 2005 | 07:46 PM
AaronT's Avatar
Sheesh!! Now mine is getting the sympathetic howl too at under 20.
Old Mar 20, 2005 | 08:50 PM
BLKHO600's Avatar
yeah it sucks.... BTW the dealer finally called me in... so no National Back Order I guess..LOL!!! cool will update who she purrs after install....
Old Mar 21, 2005 | 11:28 AM
Tiara3100's Avatar
Is it fixed???
BLKHO600, Did they fix your truck and if so, what did they fix??????
07BigHornRam
35
Jan 27, 2011 10:45 AM
Pav1973
Jul 14, 2008 10:33 PM
mr T
Jan 14, 2006 11:48 PM
hopak
Nov 12, 2005 09:58 AM
angleiron
Mar 5, 2005 09:44 PM
