noisy ac in dash?
Old Oct 20, 2009 | 05:10 PM
thames1948's Avatar
noisy ac in dash?
Well it had to happen , my ac was working fine untill I started my truck and the ac is now making a loud humming or vibrating noise. Happened all at once, never did this before. The ac is still works,but when it's on high, it's loud It gets louder the more I turn it up. Anyone elese ever had this problem?
Thanks.
Old Oct 20, 2009 | 06:46 PM
8Valve's Avatar
Yup, exactly the same problem on my 03!
Look under the glove box, there is a blower motor. I traced the noise to that motor. I was going to pull the motor ( only 3 or 4 screws). No need to pull the motor, all screws were loose, real loose. I tightneed them.......no more noise. Hope this simple fix will solve your problem.
8Valve
Old Oct 20, 2009 | 08:32 PM
Jeff in TD's Avatar
The other possibility is the recirulation door may have broken and dropped into the fan.
If you remove the glove box, you can see the recirculation intake grille, and if set to fresh air, you would be able to see the door if it is still in place.
Old Oct 21, 2009 | 05:43 AM
thames1948's Avatar
Thanks guys, I will try that
Old Oct 21, 2009 | 12:31 PM
ssandlin's Avatar
If it is a broken recirc door, remove the blower motor and the recirc door should be laying right there in the hole. Wiggle it around just right and it will come out of the hole.
From there, it's up to you whether or not to fix it. There are those that have chosen not to replace it.
NoSparkplugs
17
May 17, 2009 10:36 PM
Mechanos
Jul 6, 2004 09:26 PM
crlnmry
Oct 19, 2003 10:07 AM
dart440_72
Aug 1, 2003 03:14 PM
Marine
Nov 2, 2002 10:48 PM
