Miles between oil changes
Old Aug 23, 2007 | 11:05 PM
dogcamo's Avatar
I'm considering starting to use Amsoil 15W 40 HD Synthetic motor oil. I would like to know what kind of mileage are you all are changing oil at using Synthetic. Is it true that uder normal driving conditions I could get 15k between oil changes.
Old Aug 24, 2007 | 11:12 AM
soulezoo's Avatar
DTR 1st Sergeant
Yes, that is true.
For best protection on extended drain intervals though, I would also recommend strongly the amsoil BMK-11 oil bypass system and filter.
Old Aug 24, 2007 | 11:14 AM
06 DIESEL's Avatar
Everyone's truck is different. If you want to extend your change intervals then I highly recomend doing oil analysis to find out if you should. I can go 15-20k on my oil before it needs changed and I do not run synthetic, I run a parafin based oil.
Old Aug 24, 2007 | 12:48 PM
ShaneCTD600's Avatar
I go 10k on my Amsoil. But that is the normal drain interval.
Old Aug 24, 2007 | 01:21 PM
soulezoo's Avatar
DTR 1st Sergeant
I agree with above to use oil analysis to make sure what you are doing is ok.
Old Aug 24, 2007 | 02:32 PM
Roperteacher's Avatar
Owners manual says you can go 15,000 NON severe conditions on Dyno!
Old Aug 24, 2007 | 02:56 PM
surfram's Avatar
I go 7,500 miles on Rotella 5-40 synthetic.
Old Aug 24, 2007 | 04:05 PM
driver612's Avatar
i go 30000 mi on rotella syn.
driver612
Old Sep 27, 2007 | 02:33 PM
CrazyCooter's Avatar
I run Amsoil AME 15w40. I went 11k on this last sample and it was too long.
Soot was way to high for my short trips.
I will try another sample @ 5K and see what happens from there.
More fuel mods mean more oil changes.
A bypass filter is always a big plus.
Old Sep 27, 2007 | 03:34 PM
Owners manual says 7500 severe duty, 15,000 Non severe on Dyno... I change my dyno every 3000 because I like to bond with my truck!
Old Sep 27, 2007 | 04:28 PM
rjm022's Avatar
i use that oil- but i also have the amsoil single bypass set up- i am changing oil at 20,000 miles. oil analysis says i can go longer-but 20,000 miles is my limit
Old Sep 27, 2007 | 04:32 PM
Dieseljunkie's Avatar
I've said it before, and I will say it again. I am going 25k between oil changes on this batch of Amsoil AME 15w40 HD diesel and marine motor oil. The plan is to do an oil analysis every 5k or 3 months, whichever comes first. Amsoil says that you can go up to 25k between oil changes for normal use. I only tow once or twice a year, and its only about 7k lbs when I do it. Oil analysis results will be posted here:
http://www.dieselbombers.com/showthread.php?t=4726
Dogcamo, you have a PM
Scott
JBradley500
23
Jul 27, 2011 06:10 PM
winkdemon
Oct 19, 2008 11:50 AM
PZM123
Feb 27, 2006 10:27 AM
tfarmer96
Mar 23, 2005 11:06 AM
blackdevil
Oct 24, 2004 07:55 PM
