The Infamous HVAC Door Issue Strikes
Old Aug 26, 2010 | 12:35 PM
  #181
ssandlin's Avatar
Yep, sounds like the recirc door. Real easy to check, just pull the glove box and look.
No experience with the Heater Treater doors. When my recirc door broke, I just replaced it with the new housing/door assembly from Dodge.
Old Aug 26, 2010 | 12:48 PM
  #182
gpshemi's Avatar
...and how long has that held up for ya? It's alot cheaper then HeaterTreater I'm sure, but HeaterTreater sounds like a one shot deal. Never again with the exception of maybe a motor going out.
Old Aug 26, 2010 | 09:46 PM
  #183
FMB's Avatar
FMB
Originally Posted by gpshemi
...I'm guessing the recirc door dropped over the blower. Correct?.
Youp, the quick $0 fix is to take out the blower motor and pull the dropped door out, put the motor back.
Is the metal HeaterTreater doors worth it? ... I KNOW I don't want to do this again, and my megacab's AC/heat never has been 100% great IMO.
You are the one to decide if it is worth it. I've been without the recirc door for a few years now. I have the part, but not the real need, I guess. It was 107* here Tuesday. I drove 35 miles home during the heat of the day and had no issues. I would suggest, though, if you decide to do it, do them all and make sure they move smoothly before you put it all together.
Old Aug 27, 2010 | 12:36 PM
  #184
ssandlin's Avatar
I had it replaced in Aug of 09, so it's been a year now. If I remember right, the new recirc door housing has stops built into it to prevent overtravel of the motor. It was the overtravel that was causing the doors to break.
Old Aug 27, 2010 | 03:07 PM
  #185
15 Digger's Avatar
Originally Posted by pet05
Well, I was hoping that it would not happen to my truck but at 10,400 miles, it struck, the infamous HVAC door issue. I was ALWAYS careful to keep the fan ON LOW when switching from recirculation and then back to outside air. But it still happened to me.
I went to turn the A/C on and even while the fan was on FULL SPEED, very little air is coming out the vents. It doesn't matter if you switch from recirculation to outside air, the air coming out of the vents is weak, even at FULL FAN SPEED.
I REALLY do NOT want to take it to the dealer. Even though it is under warranty, I have read that they can end-up hacking it and you will then have squeaks and rattles from your dash.
QUESTIONS:
1 - Is it the BLEND DOOR or the RECIRC DOOR that broke?
2 - Can I just rip out the door myself and be done with it? What are the negatives of doing this?
3 - I've read where guys just removed the door by reaching in from the glovebox. Does anyone have links/pics of this?
4 - Did D/C finally come out with a BETTER design?
If the dealer is the last resort, can anyone recommend a QUALITY dealer in Colorado that they have taken it to and they fixed this issue CORRECTLY without causing more problems (squeaks, rattles, dash scratches?)
My 06 did it also by 10K miles. Dealer fixed it.
Old Aug 28, 2010 | 11:09 AM
  #186
rsscoggins's Avatar
Well my Recirc door broke first part of the summer - fan was on high sounding like a tornado but very little air coming out of the vents. I dropped the fan motor and sure enough the door was laying on top of the fan blocking all air flow. I simply removed it and put the fan back up with the intention of replacing the recirc door later.
Recently I had to do some AC work on the wife's Z28 so I bought some gauges and a thermometer. I stuck the thermometer in my trucks center vents just to check it out and noticed a 20 degree difference between driver and passenger - driver was colder so I never realized it. This differential didnt sound right and I didn't know if it was because of the recirc door missing or if it was low and R134a as others suggested.
Earlier this week, I ended up ordering the HEATERTREATER recirc door instead of the OEM plastic one. This thing is ridculously simply and most anyone with fab skills could make it but you have to admire the guy for making and marketing a product that is better than the OEM one. I installed the metal recirc door WITHOUT cutting the dash by inserting it through the fan motor hole the same way I removed the original. The instructions were for all doors and man I can not believe that people would cut up the AC plenum like that - simply crazy. There is no need to cut or even remove the plenum for the recirc door, just go up through the fan motor hole. IF i ever have to replace the other doors, I WILL use the Heater Treater doors but wil remove the dash and ac plenum rather than cutting.
I also added 3/4 of a can of R134a to the AC system and now both passenger and driver cool down to 42 degress on a 91 degree day.
Old Aug 29, 2010 | 09:13 PM
  #187
04ctd's Avatar
how do you get the ReCirc door to close against highway speed wind coming?
my recirc makes a HORRIBLE wind noise at speed.
it's louder than the K&N was on my 2004.
Old Aug 31, 2010 | 10:32 AM
  #188
User Name:'s Avatar
are you guys able to seal off the recirc door with just dropping the fan motor?
Old Aug 31, 2010 | 10:44 AM
  #189
gpshemi's Avatar
Pull the fan last night and yanked out the recirc door. I'm not smothering now at least. The AC isn't quite as potent, but this was 90 in Michigan and seemed to cool the megacab down enough. The dealer tech told me not to bother putting it back in. The newer assembly (Door and box) was only $47, but didn't look much different to me. It's black and has foam on the entire face of the door.
I think I'll let it ride a while and see, but if I do tear into it, I think for the extra $150, the heatertreater steel solution is probably worth while. I doubt you'll have to tear into it a 2nd time after that fix.
Old Aug 31, 2010 | 11:07 AM
  #190
User Name:'s Avatar
ya pulling outside air is no good for me here in houston, unless pulling 100 degree air and 50-60% humidity seems pleasant
Old Aug 31, 2010 | 12:33 PM
  #191
ssandlin's Avatar
You also need to yank the glove box out to get access to the recir door box. Last summer when my recirc door broke, I secured it in place to the plastic grate over the opening using plastic zip ties inserted into holes I'd drilled in the recirc door itself. In this position, I did not have recirc (outside air only) and with the 105+ deg. temps we were having last August, it was not long before I had the recirc door assembly replaced so I could recirc the air. Made a huge difference in how cool the cab got.
Old Aug 31, 2010 | 12:39 PM
  #192
User Name:'s Avatar
i was thinking if you just covered the hole completely wouldnt it always be on recirc?
Old Aug 31, 2010 | 10:09 PM
  #193
FMB's Avatar
FMB
Wrong hole, User.
Old Aug 31, 2010 | 10:15 PM
  #194
User Name:'s Avatar
**** my girl said that too me last night
Old Sep 1, 2010 | 07:17 AM
  #195
gpshemi's Avatar
Depending on which hole you cover yes. However, I don't think you want recirc all the time right? You'll fog up I'd think. Seems to be working pretty good as is really. It's been in the 90's the past few days, and I'm keeping up just fine.
