Gauge Problems
Old Nov 27, 2010 | 05:30 PM
campnfish's Avatar
Gauge Problems
I was doing some work on the gauge cluster and long story short I popped off all the gauge needles. I thought maybe when I started the truck the needles would "zero" themselves. Now they are all off- the speedometer is 25 mph low, tach is about 500 rpm low and temp gauge is high. Is there any way to reset the guages? I did do the hold trip reset and turn key on, seems to go through all the tests then acts the same.
Any help will be appreciated!
Old Nov 27, 2010 | 05:39 PM
torquefan's Avatar
The only way to fix this that I am aware of is to pop the needles all back off then put them back on in a known accurate location. I had this experience once with a speedometer on a Ram. I had to plug in a scanner and monitor the vehicle speed with it while driving down the road. When the scanner read 30 MPH, I stuck the needle back on, right at the 30MPH mark. Hopefully you can do all yours this way.
Old Nov 27, 2010 | 10:08 PM
campnfish's Avatar
Does anyone know what the gauges should read when you're doing the gauge check?
DJ Turbo.
Oct 13, 2011 09:11 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
Contractor
Feb 10, 2003 08:58 PM
Contractor
Feb 10, 2003 07:34 PM
