Creaking noise from the bed.
Old Mar 11, 2005 | 07:00 AM
  #31
Buzzer's Avatar
Originally posted by Hounddog
Mine is much more pronounced and frequent in cooler temps.20s and low 30s on a right turn and a incline or bump etc.it bangs POW.In warmer temps its very rare if at all.Be rolling and shift to 3rd gear turn hard right and hit a small pothole on the edge of the road with rear wheels in cold temps and POW you'd think someone under the right side of rear seat/bed area hit it with a sledge hammer one quick hard blow.
Exactly the same thing I have. Exactly.
Old Mar 11, 2005 | 10:55 AM
  #32
Hounddog's Avatar
Well what is it.I thought maybe a shock binding??Just a gues tho.
Old Mar 11, 2005 | 12:39 PM
  #33
Buzzer's Avatar
I really have no idea. My 97 did it too. Same noise same situations. Kinda nuts.
Old Mar 12, 2005 | 06:21 PM
  #34
tripper=t57's Avatar
I have a similar thunk I have heard a couple of times. I replaced the bed with hauler bed and thought it might have been a bolt not completely tight , but they are all good. It may be that the frame is rigid enough that some sheet metal, tank cover whatever is popping in and out like a diaphragm when it gets in the just right spot.
Old Sep 11, 2006 | 02:09 PM
  #35
ld5030's Avatar
I had an annoying squeek appear immediately after adding nerf bars. My first thoughts were I reefed down too much on the bolts as I also did not use a torque wrench
Old Feb 26, 2018 | 02:30 AM
  #36
orianer's Avatar
Hey guys,
Pleasure knowing - my name is Eran from Israel.
I also have a dodge ram 3500 which had the same issue - banging noise when driving coming from the bed are. The noises begun after installing bed bars.
The solution i found is:
1. disassembled the bars.
2. The side which the bangs came from (right side) - took the vehicle on the stairway to twist the frame a bit.
3. Opened the cargo door and pulled at the far end of the bed - close to the cargo door.
4. Closed the bed door.
5. Drove down from the stairway.
It is important to close the bed door while still on the stair and close the door, only then to step down.
To me it helped - hope i can help others.
wackodacko
Jan 9, 2010 11:19 AM
mopar-or-no-car
0
Mar 5, 2009 04:10 PM
njmaier
Sep 11, 2006 07:27 PM
06Cummins
Feb 25, 2006 08:31 AM
