chim alarm
Old Nov 23, 2003 | 10:36 PM
hammerjammer's Avatar
chim alarm
the chime alarm would start bonging while cruising down the road,the lamp out light ccmes on,I stop and check,but no bulbs are out.The fix is to dip the bulb sockets in grease. Some of the 03 trucks had the bulbs installed dry. resistance builds up between the bulb and socket and the computer see's this as an open circuit causing the alarm to go off and lighting the lamp out warning light.
Old Nov 24, 2003 | 06:14 AM
SuperGewl's Avatar
Re:chim alarm
Did you replace your taillamps with APC taillamps? Because if you did and got the original ones offered by them at the beginning of the year they would cause the same lamp out alarm but the lamps would work just fine. They finnally have come out with replacement lamps for them.
Old Nov 24, 2003 | 06:22 AM
Re:chim alarm
I just dipped the original bulbs in grease,so far the problem has not come back.Thanks for the info.
Old Nov 25, 2003 | 05:48 PM
dodgedude361's Avatar
Re:chim alarm
APC? tail lights? whats that? i have that problem too, seems to do it when it rains. now if i could just figure out how to get at the bulbs ??? ???
Old Nov 25, 2003 | 07:33 PM
Re:chim alarm
The owners manual gives good directions to get to all the bulbs.Dunk the base in grease and re-install bulbs fixed the probablem for me.Probably your rear bulbs.
Old Nov 25, 2003 | 09:51 PM
Berak's Avatar
Re:chim alarm
Of course I'm sure hammajamma is referring to dialectric grease, not just any old grease, in case anyone doesn't know that.
Stormin_Norman
Mar 4, 2004 12:45 AM
L. D. Bryant
Apr 1, 2003 09:07 AM
wick
Nov 15, 2002 02:54 PM
BIG&BAD
Nov 6, 2002 01:53 AM
