broken recirc door
broken recirc door
My recirc door broke last fall. I removed the blower motor and pulled out the broken pieces, thinking I would fix it in the spring. We went on a mini family vacation, my wife complain that there was cold air coming from the vents on the pass side of the truck. I was sweating trying to keep her comfy. Since spring is coming and the dash will need to be remove to replace the blend door is there anything I need to check for the cold air problem? I'm a computer idiot, could someone in readerland post a link to the dashboard removal and blend door replacement procedure that was posted several months back? I did a search and came up empty-handed. Thanks
The cold air is a result of the recirc door being gone. Here's one link
https://www.dieseltruckresource.com/...d.php?t=170393
As already said, there are many threads on this subject. Good luck!
Mine broke last summer on vacation out west. I was in Leavenworth, Ks visiting family. I took it to a local dealer.
They quoted me about 5/6 hrs.labor with a total about $600 or so. The mechanic showed me how easy it was to remove the fan motor and reach in and remove the broken door. The problem arises if he is not able to retrieve the broken off piece. In my case I lucked out and the piece came out. The out the door total came to around $270 so I felt pretty good about the outcome. So, give it a go and see what happens.
Good luck with it
Good luck with it
my dealership tech keeps a couple of these in his toolbox, he saves his time (which he is paid the 5 hrs for) and sells the warrantied parts...
-sean-
69
Aug 25, 2015 12:35 PM
Tomtt
Aug 12, 2008 10:53 PM
pet05
18
Sep 21, 2006 09:21 PM
TonyB
Sep 13, 2006 09:22 PM
