broken blend door
Old Jan 11, 2009 | 06:54 PM
xtoyz17's Avatar
How can you tell if the recirc door is working? I push the button but I can't physically hear anything moving? Is it a noticeable sound? I've not reason to believe it doesn't work other than curiosity
Shawn
Old Jan 11, 2009 | 08:26 PM
Jeff in TD's Avatar
Open the glove box part way, pull the back corners inward, and rotate the glove box down and remove it.
You should now be looking right at the recirculation intake. The tanish flapper (blend door) should be visible in the intake grille if it is set to fresh air, and you should see it move if you switch it to recirculate.
Old Sep 9, 2014 | 09:24 AM
ktrue's Avatar
I would like to mount the flapper door and secure it in the rec. pos. Which is rec. pos. Up or down?
Old Sep 9, 2014 | 02:33 PM
Jeff in TD's Avatar
The photo above shows the door blocking the recirculation intake grille, in the fresh air position.
The recirculation position has the door tipped up, blocking the fresh air passage.
Old Sep 10, 2014 | 12:15 AM
ktrue's Avatar
Thank you so much Jeff. I realy appreciate this info very much.
Old Sep 10, 2014 | 02:33 PM
Jeff in TD's Avatar
If you drop the motor and look up, you will see the fresh air passage in the top.
terryKS
15
Aug 22, 2009 02:18 PM
Tommy93w350
Sep 28, 2006 02:53 PM
Tommy93w350
Oct 27, 2005 08:11 PM
premo 1
Sep 24, 2005 09:03 AM
