AC/Heat Blend Door removal
Old Oct 25, 2005 | 08:07 PM
Tommy93w350's Avatar
My blend door is sticking and not turning. The motor is fine. I have to manually turn the door with a wrench at the motor for cold or hot air.
I need to replace that door or see what's sticking. I can I access the door if I pull the dash out, but not completely removing HVAC box? Maybe just the top half?? Or would the whole box have to be removed?
Old Oct 25, 2005 | 11:10 PM
J BODY's Avatar
whole box should be removed.
Old Oct 26, 2005 | 06:47 AM
premo 1's Avatar
From: St. Louis, Mo Home of Busch& Budwiser Beer and Kurt Warner---opps I mean the RAMS
Would you mind telling me where the blend door is located and what it looks like. I thinks mine is sticking too.
Old Oct 27, 2005 | 08:11 PM
On the passenger side, towards the hump, at the very bottom of the big black HVAC system. There is a couple of wires running to a small motor. The motor shaft is vertical and held in by two screws. One is easy and the other is a pain in the butt.
I broke part of the blend door shaft that connects to the motor with my pliers. Now I must replace or fix it.
terryKS
15
Aug 22, 2009 02:18 PM
Flashman
Oct 26, 2007 08:46 AM
jon96ctd
Mar 14, 2007 02:37 AM
premo 1
Sep 24, 2005 09:03 AM
