BRAKE CONTROL WIRING QUESTION
Old Nov 23, 2003 | 03:18 PM
RACER47's Avatar
Just received my brake controller and it has 4 wires coming out of the back of it. My question is do I splice these into the harness somewhere, or is there a plug I can connect to the bare wires that will just plug into the harness somewhere under the dash
Old Nov 23, 2003 | 04:46 PM
Briman's Avatar
Re:BRAKE CONTROL WIRING QUESTION
Hi, On my '03 there is a blue connector on top of a major electrical connector above and maybe a little left of the clutch peddle. I don't know if all trucks have this connector or just ones equipped with the trailer tow option. If you got a truck with the tow package the mating connector (also has a blue connector) with some pigtail wires on it for connecting to your controller came in a plastic bag with a sheet of paper or two with directions for its use. Look and see if you have the blue connector under your dash and if you did not get the matching mating connector with your truck PM me with your address and such and I'll send you a spare unused one I have. Did that all make sense?
Old Nov 23, 2003 | 04:52 PM
DF5152's Avatar
if you got the trailer tow package you should have gotten a connector with a blue end on it the plugs in uder the dash no other wiring necessary..
Old Nov 23, 2003 | 06:08 PM
RACER47's Avatar
I see the mounted blue plug under the dash, but i dont have the other end to plug into it.(the one with 4 bare wires sticking out of it) I could splice into the rear of the plug, but i would rather get the plug that goes into it
Old Nov 23, 2003 | 06:54 PM
Patrick Campbell's Avatar
I will send you an extra wiring harness. PM me your address and I'll get it out tomorrow.
Old Nov 23, 2003 | 07:20 PM
RACER47's Avatar
Ok, thanks ! One question. How do i PM you?
Old Nov 23, 2003 | 07:39 PM
Rolngthun's Avatar
[quote author=RACER47 link=board=17;threadid=22772;start=0#msg213232 date=1069636814]
[/quote]
Click on his name.
Old Nov 23, 2003 | 08:35 PM
or email me patrick@cdevco.net !
I bought a truck and traded it in a few months later and I stole the extra wiring harness and my floor mats before I traded it in muhaha!
Old Nov 23, 2003 | 08:48 PM
RACER47's Avatar
did you get my PM?
Old Nov 23, 2003 | 09:21 PM
Vittorio's Avatar
Just a heads up for those of you with the towing package and can't find the brake controller plug which is normally located under the dash to pull down and connect. Mine was buried deep under the front driver's side carpet. We had to pull the carpet fully back to get it out. We just about gave up looking for it when we discovered it about an hour into the installation. Hope this saves someone the time we wasted. >
Old Nov 23, 2003 | 11:24 PM
Jim O's Avatar
I would recommend putting a diode in the blue wire to stop a reverse feed from frying the brake control if the beakaway is pulled. The one I use is a Caterpillar part #2W4899. I am sure you could find a cheaper one ( I used to work for the Cat Dealer before I retired). I have transfered this diode from the last three vehicles I have owned.
Jim O
Old Nov 23, 2003 | 11:33 PM
RACER47's Avatar
Thanks for the tip jim. I run a backhoe for a living and the cat dealer is just down the street ;D
Old Nov 25, 2003 | 10:57 AM
majordad's Avatar
Does it have to be a Caterpillar Diode or can i get one at Radio Shack?
Also, anybody know if the Tow Package wiring is just to accept the braking controller or is it able to engage "uncontrolled" electric brakes through the big jack on the bumper?
Thanks in advance
nailhead
Apr 4, 2006 10:44 PM
duallydave
Jun 11, 2005 10:38 PM
duallydave
Jun 9, 2005 01:31 PM
duallydave
Jun 3, 2005 10:43 AM
charcoal600
Apr 30, 2005 02:34 PM
