Blinker problem
Old Jun 3, 2008 | 02:49 PM
sickandtwisted's Avatar
Blinker problem
I started noticing it more and more lately that when i put on my left blinker my right one comes on as well. Even wierder is that sometimes when I attempt to put the left on the right come on by itself, no left blinker at all. The right blinker functions normally at all times, the issue is only with the left.
Any help?
Old Jun 3, 2008 | 03:16 PM
BMH95's Avatar
You're low on blinker fluid.
Old Jun 3, 2008 | 03:17 PM
BMH95's Avatar
I had to do it, sorry.
I'd say something shorted in the steering column, or the wiring from there to the fuse panel up in the front, under the hood.
Old Jun 3, 2008 | 03:19 PM
Gary Emerald's Avatar
also check all your wiring and grounds... if you've got a bad ground on the left circuit, it could be grounding out to the right circuit somehow. check the bulb sockets for corrosion, etc.
had this hapen a few times on some older Fords... scratched my head for a while and then found some cruddy bulb sockets and replaced all the bulbs (they're cheap enough)
problem went away both times
Old Jun 3, 2008 | 03:30 PM
PEAKSTRYDE's Avatar
I had the same problem, Check the 4 way flat trailer plug on the back of the truck!!!!!
Mine was melting together into a big mess!!!!!!
The cap on the 4way is about the worst thing ever as far as holding in the road "salt/sand/slime/junk"
Old Jun 3, 2008 | 04:05 PM
steelblitzkrieg's Avatar
DTR Detective
Bad multi-switch most likely. I know the 06's are on a service watch for them.
Old Jun 4, 2008 | 01:15 PM
ToyKraz's Avatar
+1 That's were I found the problem when mine started it.
Old Jun 4, 2008 | 02:41 PM
BMH95's Avatar
I had a friend have that happen on his 04 dually as well - the 4 pin plug under the bumper, that is.
Old Jun 4, 2008 | 03:01 PM
TheRedlines's Avatar
Sounds to me like too much blinker fluid.
Old Jun 6, 2008 | 02:55 PM
This sounds like it will probally be the answer. The truck has seen some dirt, I'll check it out
Old Aug 23, 2009 | 11:22 PM
Wow it's been a while. Finally got around to getting it to a competent dealer who figured out it was a bad multi-function switch
jaconst
Nov 20, 2010 09:05 PM
rocksteadyrobk
Dec 1, 2009 07:49 PM
Nape
Nov 9, 2008 03:19 PM
Rick_Orcutt
Aug 1, 2007 07:13 PM
Jme
0
Dec 7, 2006 05:10 AM
