Blinker brake light problem
Old Oct 9, 2008 | 11:30 AM
Nape's Avatar
01 dually used to deliver trailers on the road no flasher, blinker, or stop lights. can't find a blown fuse, can't find a flasher, HELP Nape
Old Oct 9, 2008 | 12:02 PM
leftturn7m's Avatar
Did you check the relay under the hood?
Old Oct 9, 2008 | 12:04 PM
high bid's Avatar
what about checking your blinker fluid?
Old Oct 9, 2008 | 01:00 PM
johnh's Avatar
are you saying you can't locate your flasher or can't find a replacement
Old Oct 9, 2008 | 01:14 PM
johnh's Avatar
the flasher is located under the cover at the extreme left side of the dash, you have to open the drivers door to access it... and it has "fuse access" on the cover . on mine it's the square blue one
Old Oct 9, 2008 | 01:17 PM
johnh's Avatar
Old Nov 9, 2008 | 03:19 PM
jbone's Avatar
I assume you still have tail lights. My 01' CTD did exaxtly the same thing. Turned out the trailer had a short in the brake wiring, and it burned up my brake light switch and flasher at the same time. Your problem could be as simple as burned out bulbs, but try this first. Unplug the trailer, unplug the brake controller (should have a snap-in plug on the back where the wires go into controller), and do the following; Check and see if the 4 way flashers work. If they do, then you know that the 4-way flasher is good, and that both of the stop/turn bulbs are good. Open the fuse panel at the Left end of the dash (access cover faces driver's door), and swap places with the flashers. If you don't have burned or broken wiring, or a blown fuse, that should give you turn signals. Check all fuses under the hood and in dash fuse panel with circuit tester, or pull each fuse and check with ohmmeter. If none are blown, check the brake light switch under the dash on the pedal. 1 wire should be hot all the time, both should be hot when pedal is depressed. Good Luck. Joe
Joey-D
Dec 12, 2011 12:52 PM
TMan
Dec 25, 2007 01:52 PM
CORed
31
Mar 30, 2007 12:13 PM
dgibbs
Mar 11, 2006 07:35 PM
mikmaze
Feb 13, 2005 12:23 PM
