front blinker problem
Old Nov 29, 2009 | 02:35 PM
rocksteadyrobk's Avatar
I have no front blinkers. I just got back from a road trip and had a burnt out rear tail light, both front marker lights were burnt out. I have a fab four bumper with the marker lights wired up to fab fours specs. Everything worked fine for weeks.
I replaced all the bulbs and everything that was burnt out now works. All fuses are good. The rear blinkers work fine but the fronts do not.
What could it be. Is there a relay I am missing. From what I understand these trucks have some quirks when it comes to lighting and wiring.
Thanks,
Old Nov 29, 2009 | 03:16 PM
bansh-eman's Avatar
A shorted wire in your harness maybe?
Old Nov 29, 2009 | 08:25 PM
forwardho's Avatar
Check for a loose ground wire.
Old Nov 30, 2009 | 12:57 PM
davidj54's Avatar
Both front lamps are fed from the TIPM. They're fed different from the rears. If you didn't use the factory grounds I'd bet grounding is your problem. even if you did, I wouldn't rule it out.
Old Dec 1, 2009 | 07:49 PM
fixed it..
Although there were no codes or check engine codes present. I cleared the codes with the smarty and I now have front blinkers. So I guess it was a function of the TIPM.
It was a short in the fab four marker light that was in the socket. all fixed.
Thanks,
jaconst
Nov 20, 2010 09:05 PM
sickandtwisted
Aug 23, 2009 11:22 PM
Nape
Nov 9, 2008 03:19 PM
Rick_Orcutt
Aug 1, 2007 07:13 PM
Jme
0
Dec 7, 2006 05:10 AM
