Bad brake job?
Bad brake job?
Hey all,
Had my brakes done a couple a months ago at my dealer. Had the rotors turned and bought the better oem pads from DC. Now my trucks shakes much worse when braking than before I had the brakes redone!!! Did I get a poor brake job? Can one mess up turning the rotors? Will the service writer try to sell me new rotors?
thanks
Jamie
thanks
Jamie
How many miles do you have? The rotors should still be under warranty if you're under 36K.
If you are over 36K then suggest to the dealer that your brakes now shake the truck worse than before you brought it in. Insist they turn the rotors again and make them "true" and if they can't be turned again then they owe you a new set of rotors.
Rotors are out of warranty at 12k/12months. I've had great success using the "Value Line" pads at work. I'm assuming they used the Pro Cut on car lathe. It's a dealer required tool. I wouldn't cut a rotor off the car/truck anymore.
Sounds to me like they turned the rotors undersize and they got hot from use and warped. Wouldn't matter if it was a dealer or Joe Schmoe's Brake Job Emporium, somebody owes you new brakes. To answer the question, you bet they can screw up a brake job! If the rotors aren't thoroughly cleaned before chucking them up in the lathe, it's just luck if they turn true.
Thanks all,
I have 82K on the truck. No I didn't tow anything. Just a daily driver.
I will bring it up to the service writer, but I'm not expecting him to bend over backwards at all for me. I've always had little to no luck at all dealing with DC.
thanks for the input
PS the same tech that did my brakes messed up putting in a new lock mechanism on my driver door.
Jamie
Jamie
If I am not mistaken, the factory rotors are cryo treated for better heat handling. If they turned them you may have warped them and also destroyed the cryo treatment. I would never have rotors turned anymore. Much better idea to replace them. Of course with cryo-treated rotors, this is pricey!
