05 3500 6spd Qc drw opinions please
Old Mar 18, 2006 | 12:53 PM
Dodge Trucker's Avatar
I am looking into a used 05 Qc 3500 drw w 6spd and wondering what to look for as far as wear and tear. Also what fuel milage are people getting hand calculated.
Old Mar 18, 2006 | 01:22 PM
tankeryanker's Avatar
Just check it out good for flood damage. It seems some katrina vehicles have been slipping through the cracks.
Mine is 4x4 I get 12 mpg at best towing my 12,000 lb 5vr & 17.5 at best empty but she only has 4600 miles on her.
Old Mar 18, 2006 | 04:03 PM
FiverBob's Avatar
If it is anything like my 03 HO six speed, you will love it. I have 45,000 on mine with no problems other than the take off shudder when loaded. I think they have a handle on that now.
Bob
Old Mar 18, 2006 | 09:44 PM
horsepoor68's Avatar
I get about 13 to 14 mpg about 10 pulling my flatbed empty. thats on the interstate doing 75 to 77 mph i usually just set cruise and let it go.
Old Mar 19, 2006 | 02:57 PM
12PACK's Avatar
Which 6 speed does it have? The NV5600 (reverse on the top right) or the higher geared G56 (reverse on lower left).
Old Mar 19, 2006 | 03:32 PM
underwoodtransp's Avatar
I don't have a manual but with 4:10's I get about 9 towing the big gn trailer and about 16 on the highway running 80mph. also if it is a 4x4 the main things these trucks see are ball joints. Jack the front end up and useing a prybar see if there is any play in the steering knuckles up and down. if so it needs joints and they aren't cheap. run about $100. a pop x4. and also while in the air check tie rod ends and track bar looseness. other than that all is good!
Old Mar 19, 2006 | 04:59 PM
bekim's Avatar
Run the VIN for title search(owner history). Take it to a Dodge Truck dealer and have them give it the third degree.
Cheers
Mike
Old Mar 19, 2006 | 11:27 PM
It has the NV5600. I'm going to drive it tommorow. Hope it has the 3.73 gears. Is there a gear ratio tag on the rearend?
Old Mar 20, 2006 | 09:58 PM
bluebull's Avatar
2000 RPM at 63 MPH = 4:10 gears
2000 RPM at 69 MPH = 3:73 gears
Old Mar 21, 2006 | 01:07 PM
Mixer Man's Avatar
The gear ratio will be listed in he glove box and on a tag . I have the 3.73 in my dually and it is perfect for pulling 15,000 lbs . Mileage really improved when I started running Stanadyne Perf Formula add 2 - 8 oz. every fill up & I have not had any injector probs at all . I am amazed at how smooth these beasts idle ,the Cummins N-14 ,M-11 & ISM I drove would rattle your fillings at idle ......... but boy they would pull 11 yards of concrete all day long with no complaints ! My truck just LOVES to work she gets better mileage on my overhead running with 1000 lbs in the bed than empty !
Old Mar 22, 2006 | 12:06 AM
Rambunctious1's Avatar
I'm pretty sure that the 6spds only come with 3.73's. I think that the 4.10's are only an option for the auto's.
jlipskoc
Mar 7, 2009 08:00 PM
cscott67
17
Mar 3, 2008 07:46 AM
dragginlx
15
Mar 9, 2007 11:32 AM
westport
Nov 24, 2005 01:43 AM
norsk
Jul 19, 2005 08:26 PM
