06 DRW - How do I get rear rotors off? DRW Wheels are siezed?
Old Mar 6, 2009 | 07:58 PM
jlipskoc's Avatar
This 06 came from Minnesota, 88k now. This is my first 1 ton DRW.
All the rotors are literally rusting flaking apart....
I got all 4 new wagner rotors and pads ($700) ouch.
The DRW rears rims are stuck, I can't even get the DRW wheels off, how the heck does a person get them off, I sprayed lots of PB and big hammer on the tires, no luck! Help!
I need to know how do I get the rear rotors off also.
Thanks,
John
Old Mar 6, 2009 | 09:19 PM
Hayseed's Avatar
Smack em and smack em again. If the outers are stuck put a flat wedge bar between them and smack the bar towards the center of the hub. If the inner is stuck smack the tire towards the axle. As for the rotor someone else will have to speak up because I haven't had to change them yet.
Old Mar 6, 2009 | 09:21 PM
iker42's Avatar
Ok, works for a friend of mine every time. secure the front tires, jack up the rear, loosen all the lug nuts. start the truck and put it in gear. at around 5mph slam the breaks. it should pop them right apart.
Old Mar 6, 2009 | 09:26 PM
rich's Avatar
use a sledge hit them towards the axle on opposite sides of the tire. it will work. to get the rotors off you have remove the calipers and its holder and then unbolt the axle shaft and pull it out and the rotors will come off. should take about an hour or so
Old Mar 6, 2009 | 11:06 PM
OOPS's Avatar
Depending on how rusted the bolts and pins are.
Old Mar 7, 2009 | 12:44 AM
dozer12216's Avatar
Loosen the lug nuts 1/2 turn loose and drive carefully at slow speed and make turns. Should pop loose after few turns.
Old Mar 7, 2009 | 08:56 AM
jlipskoc's Avatar
Thanks, appreciate the info. I ended up getting all the wheels off ok, what a PIA. All 6 of them literally rusted to the flanges. PB spray seemed to help, but yeah, SMACK SMACK SMACK, turn wheel SMACK SMACK on the inside of the tire with a big sledge hammer, so the hits would push outward. Took 3 hrs to get them off, talk about sore this morning. Definately putting antisieze back on the flanges when remounting the wheels.
Another 3 hours just to replace the front pads/rotors. I hate rust! lol
I put lots of antisieze on the front wheel spacer, nutz, brack caliper bolts etc. Northern US is sure hard on this stuff.... this sure isn't like my 94 !
I notice the 06 had dual caliper pistons on the front compared to the 94, and bigger pads, rotors on the rear is great, though I don't understand why the engineers designed the rear like that. Starting to like my 94 drums.
I haven't got the rear rotors off yet, that looks like all day job, can't believe you have to pull the axle to get the rotors off ugh
I've never had an axle shaft off in the rear, first do I remove the 4 nuts on the back of the axle housing flange? or does that axle cap with 6+ screw come off?
Appreciate any help anyone has with the removing axle bit to get to the rotor.... Thanks
Old Mar 7, 2009 | 12:26 PM
rich's Avatar
remove the axle cap on the end then it pulls out real simple
Old Mar 7, 2009 | 07:22 PM
jlipskoc's Avatar
Thanks Rich, will I have to buy a new seal if I pull the rear axle?
I decided to try to do the rear's maybe later in the week.
Oh too, How the heck do you get the front spacer removed from the rear rotor, another big hammer?
Old Mar 7, 2009 | 08:00 PM
rich's Avatar
no seal needed. not sure on the spacer we dont get rust here so i mite not have thought twice about it when i did it
fullmoonexp
Apr 18, 2010 10:16 AM
bradler
19
Jan 5, 2009 07:04 PM
dodgerdog
Nov 19, 2008 04:11 PM
rich
Sep 26, 2005 08:53 PM
yomitch
Nov 22, 2002 12:11 AM
