Juice With Attiude On A 6.7
Install is pretty easy takes longer running the juice control module then hooking everything up if you have the turbo cool down timer which you should it is the easiest to pull the plastic under the steering wheel off and then there is a metal plate pull that off too thats a total of 6 screws real easy then you can see what you are doing. If doing your egt probe and not sure just ask again because I think that is the most important part. If you run into anyproblems pm and I will get you my phone number
Mopar72
16
Jan 4, 2009 08:58 AM
bighornram
13
Nov 2, 2006 08:28 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
Igor
Sep 13, 2005 12:47 AM
