3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Which Chip is better for my 2007 Cummins
Old Oct 3, 2007 | 07:41 AM
steel77's Avatar
Hi,
I am thinking of installing a new chip for my 07 Cummins. I just need more Power !!
Do I have more options than Edge Juice with Attitude Monitor?
Old Oct 3, 2007 | 09:31 AM
cbrahs's Avatar
wait for the smarty. you won't regret it.
Old Oct 3, 2007 | 11:59 AM
JCLeary's Avatar
There's no wait...
You can run one now! There is a new program coming with lower smoke, however.
Smarty should be the first mod after gauges. Period. Work your way up from there
On edit:
I've not heard good things about Edge and the '07 trucks. TST does not work with '07 trucks yet either. Go with a Quad Commander and a Smarty to start. That's the way I'm leaning right now.
Old Oct 3, 2007 | 01:35 PM
wreedCTD's Avatar
SMARTY for 6.7, its gonna have a "off road" only feature!
Old Oct 3, 2007 | 03:41 PM
cbrahs's Avatar
but he has the 6.7 and from what I have heard, the smarty won't be released til mid november for the 6.7
Old Oct 3, 2007 | 05:43 PM
JCLeary's Avatar
Oops. Didn't read the sig.
I'd still wait for the Smarty.
Old Oct 3, 2007 | 06:12 PM
KMKDiesel's Avatar
I am running the edge juice hot stacked with the ts performance mp-8 and love it. But as soon as the smarty is for sell I am going to try it too. And what bad things have you heard of edge juice on the 6.7
Old Oct 3, 2007 | 06:29 PM
NOTSTK's Avatar
my juice bucks under acceleration, mostly around 1600-1800 rpm, also smokin hot egts 1580 !!! HOT HOT HOT
Old Oct 3, 2007 | 06:32 PM
CTD03's Avatar
If its bucking its running out of fuel i would say put glacier pusher pump on or fass system on to see if that helps out
Old Oct 4, 2007 | 03:58 AM
KMKDiesel's Avatar
weird mine keeps up fine with both chips and with the water meth wont go over 1350 anymore
Old Oct 4, 2007 | 04:33 PM
jmccart's Avatar
Do you 6.7 guys ever think of having like a 3'' exhaust (electircal) cutout before all the cat/filter/thingies? Instead of having it go to open exhaust sound, maybe some pipe & muffler?
Thanx.
Old Oct 4, 2007 | 04:36 PM
n0ne's Avatar
jmc, The problem with that is there would be too much exhaust pressure being re-routed to the other pipe, and would show too low of pressure on the sensors in the stock exhaust (pressure sensors before and after the DPF).. SO the truck would throw codes with that also and possibly derate.
Old Oct 4, 2007 | 05:04 PM
KMKDiesel's Avatar
One thing that would work is put y in it before all the sensors and go out the drivers side with a valve and then when you want it for power or fun put it to that side if it throws codes or starts saying your cat is full go back to stock it will clear the codes by itself.
Old Oct 5, 2007 | 12:37 PM
jmccart's Avatar
Good point. I had an 04 hemi. I threw in a y-pipe before the cats and then again after. It was a straight 3" to the rear. The y-pipe had a cat with 2 sensors behind it. It did not throw codes after doing this. But, we all know that the 6.7 smog equipment is much more complicated than just 2 regular cats with sensors.
gergthegreat
Dec 30, 2008 09:19 PM
bansh-eman
Jan 27, 2008 02:48 AM
Elk_Hunter
Oct 24, 2006 03:17 PM
cowdude
Feb 19, 2003 06:20 PM
