3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
exhaust brake
Old Jan 19, 2011 | 08:37 PM
Samuel leo's Avatar
exhaust brake
Has anyone ever had a problem smelling exhaust in the truck when using the exhaust brake? It smells like exhaust is coming out of the vents.
Old Jan 22, 2011 | 08:15 PM
Shadower's Avatar
I have noticed this before but don't know if this is caused by the EB.
Old Jan 22, 2011 | 09:27 PM
MTRK2002's Avatar
I would check for an exhaust leak around the turbo or under the cab your hvac system may be drawing leaking exhaust in and pumping it thru the vents.
Old Jan 25, 2011 | 08:29 PM
Samuel leo's Avatar
Thanks for the advice, I thought i might be going crazy. I'll let you know what i find.
Old Jan 26, 2011 | 06:41 AM
Blake Clark's Avatar
More commonly associated with the truck being in regen. Do you notice it without the EB on?
Old Jan 26, 2011 | 06:55 PM
Shadower's Avatar
Probably why I haven't noticed it for a while.... because my truck doesn't regen anymore
Old Jan 26, 2011 | 07:17 PM
AH64ID's Avatar
Its probably indicative of a exhaust leak bewteen the tubro and manifold or manifold and motor.
Old Jan 26, 2011 | 07:37 PM
Samuel leo's Avatar
I haven't tried running the truck without the EB, I was told it was less likely to soot up if i ran the EB. So far I haven't found a leak. This is a little off subject, how often should i change my fuel filter?
Old Jan 26, 2011 | 08:06 PM
AH64ID's Avatar
Running the EB is good!
15K miles on OE fuel filters without a psi gauge.
Old Jan 26, 2011 | 08:19 PM
Samuel leo's Avatar
Where can I one of those filters with the PSI gauge?
Old Jan 26, 2011 | 08:28 PM
Samuel leo's Avatar
Never mind, I found the Air Dog on here. I should read before I speak.
Old Jan 26, 2011 | 08:37 PM
AH64ID's Avatar
Any fuel setup can have a psi gauge added, it doesn't have to be an AD. I use a Pricol 0-30 psi gauge,
rcs7
Sep 30, 2009 12:05 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
