Deleting the 6.7: A guide to making it run right!
I'm heading for #4 on this truck. But the dealer tells me to wait a while. He doesn't want any flags to pop us.
It's too bad I can't get him to put in my parts. I want to upgrade the hardware. Wish I could find out exactly what changes they made in the 11's.
First time post! I have an 08 Dodge with the 6 Spd. Has anyone deleted just the EGR? I like having clean air to hand off to the kids. Would blocking off the cooler tube result in a soft CEL? Got 15K miles till I become my own warranty station....
Cheers,
Ken
Greenville, SC
Cheers,
Ken
Greenville, SC
Cheers,
Ken
Greenville, SC
Cheers,
Ken
Greenville, SC
Ramruff
Cheers,
Ken
Greenville, SC
Cheers,
Ken
Greenville, SC
CHeers,
Ken
Increase?
Ken
Disconnecting the EGR will reduce the soot output of the exhaust. This will allow the DPF to spread out the regen cycles. Meaning it will regenerate 1/3 as much as it used too. That's where you are getting the better mileage from.
By the way, I'm doing way better than 18 highway. Wayyyy better. And I think it's even better now! I did a couple of things since my last trip.
OK, **** ol me wants to know why and how! I assume that if the EGR is not connected to the intake then that soot is in fact going straight to the DPF, which should increase the regen cycle....or, what? Also what little i've read is that the DPF regens either based on the soot load OR a numerical counter in the ECM which is dependent on the duty cycle of the engine. Lots o' questions! Now according to the overhead I'm getting 19.7 MPG which I take with a grain of salt of course. This is interesting!
Ken
Ken
Look at the blumbing
The EGR is taking raw sooty exhaust from the exhaust manifold and putting it back in the intake. They also throttle the intake air which is starving the engine for air. More soot. So it's taking a percentage of the exhust and shoves it through the intake again. Catch 22. The rest of the exhaust goes to the DPF.
A couple of years ago I ran a pipe from the down side of the DPF to the EGR. I was amazed. But my EGT's were too high because I wasn't cooling it enough. I took it out with plans of making a cooler for it. But right now, I am barely producing any soot anyway, so I see no need
So, if my '07.5 went the clandestine delete route, and later required warranty service (still have a bit left).....can the dealer tell its been molested if you remove the tune and put the dpf back on and egr back together? Does the smarty or h&s leave a footprint?
all of them leave proof on the 6.7. 5.9 smarty is the only one that does not leave a footprint.
