3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Deleting the 6.7: A guide to making it run right!
Old Jul 13, 2011 | 12:04 AM
  #241
ColoRoadie's Avatar
Add another 07.5 that has suffered from emissions parts mysteriously falling off. Odd how that happens....
Anyway, looking for MPG far more than power and tow about 7k lbs often (extra tall enclosed trailer) ...so which tune should my smarty jr be set on?
Old Jul 13, 2011 | 06:43 AM
  #242
diklohill's Avatar
I tow about 14000 lbs and am getting around 12.6 MPG @ around 62 MPH I don't remember all the settings I used but I set my HP on 70 extra . I remember I had the same Delema when I set up my Jr .
I called Smarty Jr support and they gave me suggested settings for my purpose.
Old Jul 15, 2011 | 07:55 AM
  #243
ColoRoadie's Avatar
You called Italy? Isn't that where Mads is based?
Old Jul 15, 2011 | 08:20 AM
  #244
diklohill's Avatar
No I did not call Italy -----here is the E-Mail for Smarty Jr Technical help
info@madselectronics.com
Old Jul 15, 2011 | 09:15 AM
  #245
diklohill's Avatar
timming level 3 just above no smoke HP 70 and pod 70
I leave at this setting all the time works for me get around 22 MPG on highway driving
Old Aug 1, 2011 | 10:52 AM
  #246
armourbl's Avatar
Anyone running Biodiesel in their truck after doing mods?
Only one place in the city where I live that I can buy it (near my work), but was thinking about giving it a try. Except for needing to change the fuel filter after a couple of tanks, should I be concerned about anything else?
ben
Old Sep 23, 2011 | 11:30 AM
  #247
lfd270ben's Avatar
If you delete using a dpf delete pipe with bungs and a smarty jr will the stock egt probes function? Like if I used my Bully dog as just a monitor will I see a EGT? Also is the smarty jr a download and unplug sorta thing or does it remain plugged into the OBD plug all of the time like my Bully Dog? When deleting the DPF is it better to get a downpipe while I am at it and set the Cat aside?
Thanks,
Ben
Old Sep 23, 2011 | 11:45 AM
  #248
mega-engr's Avatar
"California Style"
I am not sure about the stock EGT probes still working and being able to be read. If you have a monitor all ready, you should just go ahead and put your EGT probe in the collector pre-turbo anyway. Otherwise, it is kind of like trying to read with foggy glass lenses...
Yes, the Smarty is a plug in, and down load, then remove operation. There is a POD (power on demand) function that if you want to use it the Smarty would then remain plugged in so you can adjust when you wanted. I just adjust and remove it because I don't find the need to want to make changes...
If you don't need to bolt your stuff back on then I would change out everything from the down pipe on... I can't, so I just go with the delete pipe for the NOX/DPF and leave the CAT in...
Old Sep 26, 2011 | 06:28 PM
  #249
jfaurote's Avatar
throttle valve
any tricks to know on removing the throttle valve?
Old Sep 26, 2011 | 06:30 PM
  #250
jfaurote's Avatar
any tricks to removing throttle valve assembly
Old Sep 26, 2011 | 07:17 PM
  #251
Blake Clark's Avatar
No tricks. Just a couple of connectors and 4 bolts. Easy.
Old Oct 31, 2011 | 07:19 PM
  #252
Torquer3's Avatar
Smile The swap
Blake I wish I could have read this "Before" i did mine. I have learned alot today I finished the cooler delete (Tools needed) H&S book of directions is not correct (order wise), and other things like the Trans dip stick hanging in mid air , the ccv line also, just little tid bits that others need to know. But you article is terrific, James With RSD is good he could improve a little but he does know his stuff.I can ad too your change out to help all others be faster. Just so, all will know check your local laws ours ( i checked with DOTD ,State, and Federal laws ) emissions on Diesels Will not be implemented until 2012 so anything before do what you want and it will pass! Buy what you need from whomever but I recommend RSD just my preference, the H&S items are great , but i will call them in the am about some flaws. One thing People, if you do the Delete Do It All The Way EGR Cooler , and programmer . Fuel economy will "WILL" increase ,Power out of this world. Thank Blake for the play by play change out I wish I would have seen it sooner. Oh well we Live and learn.
Old Oct 31, 2011 | 07:28 PM
  #253
Torquer3's Avatar
Wow
Y'all make me feel realy good about my fuel economy. I get almost twenty two pulling my lead sled ( boat) no it is not slow in the water! My wife and I went too Kentucky to see our son graduate from Boot camp (yes Army for those of you ) and we were getting almost fourty on the interstate, in town I'm getting nineteen to twenty. 2007.5 Mega Cab 6.7 .
Old Oct 31, 2011 | 11:59 PM
  #254
ColoRoadie's Avatar
40 eh?
Color me skeptical....
Old Nov 1, 2011 | 08:22 AM
  #255
Torquer3's Avatar
armourbl
I know this is late I used drain plugs , in expensive and worked just fine.
