Xzillaraider2 guys in here.
#151
Just got my harness today, and everything is up and running perfectly!
Just a couple questions, does anyone know how much press hp wise dose the stacker tune add, and how do you set the low coolent temp fueling?
#153
I just upgraded to the X2 today. Love it! More power and very smooth by comparison the the old race. Had Jeremy load the race smoke for me at the shop when i was there. Then I went home and loaded hot smoke. Hot smoke is smoother to me... Don't know why really. But, when I turn on the old smoke switch... WOW. She's a smoker for sure. Very nice. I love this new X2.
I hit 42 psi boost with my 03 stock charger w/ boost elbow. The old race would only hit 37psi. Now, I'm trying to figure out how much is too much boost for my little charger.
#154
I searched this thread for info, but found nothing really. With the new X2 being black, are there indicator lights like there were on the old one? I hooked mine up turned on the key, and had no lights on the box. The control pod is lit up, and shows water temp and rail pressure, and changes levels (I think I noticed a slight tone difference when going thru them). Truck idled fine, no codes or check engine light.
I turned it back off, and held the box so I could kinda see in the USB port, turned on the key, and still no flashing lights. Gonna take it for a test drive too.
Also have to say, the factory MAP connector into the X2 harness did not "snap". I pulled it out and put it back in several times, but still no snap. It appears to be fully seated. Yes, I'm leary of this due to many issues with connectors on my X1(s).
BTW, my box model had XXX2003 on it. My truck is an 06 - does the 2003 mean anything, or are they the same box?
#155
No lights on the new X2 boxes. Internal light is only to show system is powered other than the pod working. Very nice system but like you I did have to call Justin to see where the lights are, no longer with it.
booman70
26
04-22-2008 07:03 PM
