worried about my smarty
ok so i bought a smarty yesterday and i have the juced w/attitude . i was running it on 1 cause it was raining . i picked up the smarty and was looking at it and decided to put it on in the parking lot i had to use the restroom so i left my buddy there with my stuff . well he proceded to put it on while i was gone and left the edge on 1 and i think the smarty down loaded the edge stage 1 (i think) . so if i set it back to stock then put it on another truck than switch it back to my truck would this fix his f up ? help me please thanks c.j.
if you say so you are the man about this . is it ok to run my truck on 5 all the time ? my clutch should be replaced in the next month or so ? also which setting should you tow with ? thanks.
Towing with software #3 should result in better mpg and lower egt's. You can run around empty on #5 al l day long just keep an eye on egt's to keep everything in check.
Bob,
Do you have any software that will add tranny pressure at part throttle to stop the flare in shifting from 2nd-3rd in the 06 trannies? If I'm at light throttle, the tranny doesn't build enough line pressure to make the corrrect shift from 2-3. I have a fully built race tranny, like alot of people on here do.. so I know I'm not the only one with this problem
Thanks
Thanks
