Working out the kinks-- TNT/R
Old Mar 26, 2008 | 11:01 AM
  #46
cquestad's Avatar
doug60,
You will not be able to hold SW9 with Flux 3's and a stage 2...
Try SW7 or even 5 and your truck will do MUCH better...
Old Mar 26, 2008 | 11:05 AM
  #47
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by Marco
Please, start out from the default timing setting and eventually work your way up from there. If default is not OK use timing level 3...
Thanks,
Marco
Hi Marco,
Default timing on sw9 showed the "popping" to remain as it had been. Using #3 timing on sw7 or sw9 the popping was gone. It works!
Old Mar 26, 2008 | 11:07 AM
  #48
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by doug60
Are you maintaining RP on level 9 ?
What size sticks?
Im running the 5.3 on Timing 2.
I cant maintain RP on 9. IT started poping at 60 LBS.
I dont thing it was timing related. After I watched the rail gauge falling , but maybe it was.
RP on level 9 and RP setting on #3... I was seeing 22k at WOT and holding steady. I am running flux 2.4.
Old Mar 26, 2008 | 11:11 AM
  #49
Marco's Avatar
soulezoo,
ya, I hear you loud 'n clear. I'm scratching my head tho! WHY your truck like less timing than others is confusing.
Anyway, today with the Revo we have the solution handy in the Smarty. Once found what level(s) meets the trucks needs best; voilą.
Have fun!
Marco
Old Mar 26, 2008 | 11:18 AM
  #50
soulezoo's Avatar
DTR 1st Sergeant
soulezoo,
Have fun!
Marco
So now I am concerned about adding some juice in the future... don't want to blow things up from too much timing!
Old Mar 26, 2008 | 11:24 AM
  #51
jlibert's Avatar
soulezoo,
Have fun!
Marco
tone ring mod?
Old Mar 26, 2008 | 11:26 AM
  #52
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by jlibert
tone ring mod?
Nope! I've owned the truck since new, do my own maint... tone ring has never been touched.
Old Mar 26, 2008 | 02:35 PM
  #53
cquestad's Avatar
soulezoo...
You need to change the title of your thread...these are not kinks of the TNT/Smarty...these were kinks of your rig!
Its called tuning! LOL.
You must have a female truck...since it seems so much more tempermental than my 04... LOL!
Old Mar 26, 2008 | 02:36 PM
  #54
cquestad's Avatar
Pull your timing cover...maybe your Engine was built on a Monday...and the Cam is off one tooth!
Joking...lol. Maybe not though? Hehehehehe
Old Mar 26, 2008 | 04:03 PM
  #55
soulezoo's Avatar
DTR 1st Sergeant
Oh boy, this must be pick on Terry's truck day!
Old Mar 26, 2008 | 07:27 PM
  #56
Snapoff's Avatar
soulezoo,
Have fun!
Marco
Hey Marco
Any chance that high lift pump pressure somehow advanced the timing (up set the TNT)?...It's the only thing I noticed different about soulezoo's truck?
Old Mar 26, 2008 | 10:18 PM
  #57
Pitz's Avatar
Just checking, but did everyone else lose PRND with the TNT? Also has anyone noticed the trans not downshifting when you punch it?
Old Mar 26, 2008 | 10:46 PM
  #58
Snapoff's Avatar
You adjusted the "SHIFT" option in the Smarty menu.
Put it back to "STOCK" and the PRND21 and the overdrive/towhall light will come back on.
Don't forget to reflash it or the settings will be stay the same until you do.
Old Mar 26, 2008 | 11:07 PM
  #59
gus's 03's Avatar
Originally Posted by soulezoo
OK the results are in...
I was running the early version TNT/R and could not run the odd numbered sw's due to popping sound.
Marco sent me the Revo version with TNT/R and on sw9, timing on 3, TM on 3 and RP on 3... Popping is gone...
THANK YOU MARCO!! It works!!! Injectors still rattle a little, but not too bad at all.
thats good news! what would be even better is if i could get the update as well..
Old Mar 26, 2008 | 11:14 PM
  #60
gus's 03's Avatar
soulezoo,
Have fun!
Marco
marco, whats strange is my truck normaly likes more timing than normal, but as i reported to bob a month ago when i got the first relese , i get the poping... ive gone so far as to pull 4 degrees out via the tone ring ( normaly 4 deg adv on all other softwares)
id realy like to get hold of the latest revo version so i can try tuneing it more. ( and run it with the non 04.5- presure files)
