Working out the kinks-- TNT/R
Old Mar 24, 2008 | 11:58 AM
Floor It's Avatar
Terry I talked to Jason on the pressure thing, he knows what is going on and its not a lack of rail pressure, give him a call.
John
Old Mar 24, 2008 | 12:04 PM
cquestad's Avatar
Please share the info...
I was out of fuel with my modded pump before on SW9 with Flux 3.3's...
Old Mar 24, 2008 | 12:43 PM
soulezoo's Avatar
DTR 1st Sergeant
No real info to share yet... we need to do some more tuning; Up to now this has been all smarty; we're going to hook the TST back up and start low on smarty sw... work our way up incrementally with the TST and see what happens.
FWIW, the smarty is great by itself... I just can't run the timing sw's without the popping... so we're going to dial in the timing with the TST and see at what level the popping returns.
I don't have the revo version of the TNT/R yet so I can't choose the timing options from that.
Right now, there doesn't appear to be a fuel supply issue. I get the SOTP feeling though that I am right on the edge of fuel shortage on sw8. Sw6-- no problems...
Old Mar 24, 2008 | 10:28 PM
TORQUE BEAST's Avatar
I had a lot of timing rattle with the first Non revo tune but with the revo tnt/r I have no timing issues.
Old Mar 25, 2008 | 01:44 AM
highrpms's Avatar
If this the the turck Jasons been working on you have a Stage 3 pump right? I can not imagine that your rail is anywhere dry. Do you have an injector problem?
Old Mar 25, 2008 | 02:05 AM
desertchecker's Avatar
IMO put another cp3 on there , I bet your timing rattle goes away & rp will increase ! the dual cp3 will allow a higher rp then a modified single pump
floor it modified single cp3s are nice & a big improvement over a single stocker , but the dual cp3 set up is magical they just really fix a lot of fuel problems , rattle, rail draining , etc.
I simply cannot believe 2.4 fluxs can cause any problem your describing
TNT-R on my truck #9 with added pressure of 50-60 % from mp8 = zero rattle
try to look further for a problem , it's not smarty TNT-R or fluxs 2.4 making this happen .....
Old Mar 25, 2008 | 02:19 AM
highrpms's Avatar
His CP3 in a new Floor it Stage 3. I can not imagine it is draining the rail to cause the rattle he is describing, so much so rattle that his has to run his TNT on even numbers? Knowone else has made any mention of this and some are runinng bigger sticks and a single pump. IMHO, I think something might be up with the injectors.
Old Mar 25, 2008 | 06:30 AM
Marco's Avatar
soulezoo,
that poping sound @ or arround WOT could be timing related. There have always been trucks that liked raised timing less than others. That's been the main reason that has lead me to develop the revo tunes....
On Friday I've relased a new Revo TNT/R version with revised ( slightly less ) timing. IF your poping comes from the timing than it's likely that version 5.3 will fix it. I'd try the software first before throwing parts at it.
Shoot me a PM.
Marco
Old Mar 25, 2008 | 07:52 AM
OT-OF-Here's Avatar
A couple of thoughts
Finally got everything back together and have been troubleshooting for a couple of days...
What I found was with the flux 2.4's and TNT/R, I can't run the timing settings (sw9, sw7, sw5) with the Smarty... too much timing that shows up as a loud popping/fluttering in the exhaust pipe at certain spots of WOT. At first I thought it was just draining the rail. But it is not... at least not to a great degree.
Any of the even numbered sw's (8,6,4) do not make the noise I described. As far as the rail goes, I see 22.5k max on sw 8 or 9; 23-23.5k on sw6 or 7 and 24k on sw 4 or 5. Just for fun I hooked up the puck with sw 8 and I saw a max RP of 17k on the 90 hp setting and 19k on the 60 hp setting...
So I am thinking... do I need more LP (currently at 32 psi at the pump) or more CP3? (I have Floor It stage 2) Will a modded rail help here?
Thoughts anyone??
One other comment I have to make... the HTT intercooler is just awesome. All the flogging I have done recently has made for some really high air temps from the turbos. Under similar circumstances with the stock intercooler, you could not touch (literally!!) the CAC anywhere without burning your hand. With the HTT unit, while the same temps were so hot on the inlet side of the CAC (again WAY too hot to touch the tank on the inlet), the outlet was very cool, and I would estimate (don't have the IR gun) about 70-75*. This is just surface metal temps by touch. But the difference stock to HTT is just unreal. You have to experience to believe. I was a doubter about aftermarket CAC effectiveness and benefits. I no longer doubt!!!
The rail pressure you posted is too low. You need at least 23.5k for good power and great power is 2 or 3k more for race day. I'd bet the LP is not cutting it. Another possibility,.. did you change your cam? IMO, too many guys just put in their cam and don't degree it in. That can make a major difference in the timing.
Old Mar 25, 2008 | 08:29 AM
soulezoo's Avatar
DTR 1st Sergeant
I still have the stock cam in.
Old Mar 25, 2008 | 08:36 AM
soulezoo's Avatar
DTR 1st Sergeant
You are correct, this is the truck Jason has been working on. But I do not have a stage 3. Those were not ready for release at the time I ordered-- I have a stage 2. Unless John surprised me with an early b-day present.
No, after doing a bunch of tuning runs, the rail is nowhere dry... it won't suck down lower than 22.5K WOT... LP pressure stays at 22psi at WOT...
I suppose one could opine that there is a "volume" (vs pressure) issue... but fuel is there even if "on the edge" if you will.
The noise I describe as "popping" is definitely in the exhaust and it is timing related. More tuning to follow this week.
Old Mar 25, 2008 | 10:45 AM
highrpms's Avatar
May bad I thought it had a stage three. It still seems like the stage 2 should still be enough pump.
Old Mar 25, 2008 | 10:47 AM
get the other TNT-R version from marco asap
hopefully that takes care of it for you
Old Mar 25, 2008 | 10:52 AM
Bob Wagner's Avatar
I sent Terry the new Revolution software.
Old Mar 25, 2008 | 11:40 AM
soulezoo's Avatar
DTR 1st Sergeant
Got it and will be trying it tonight. Am pretty sure using the "aftermarket injector" timing will cure the popping... I'll report back with results!
