Working out the kinks-- TNT/R
Sounds good, thanks for the info. What does the shift option do? I'll look it up and see if I can find it-- does it stretch out the shift points?
The shift option takes all the defuel out between shifts... do not use this option except at the track or dyno... or your tranny will eat itself in time.
its a seperate function 2 menu's
Shift Limiter*** : Two levels.
# 0 ; Stock value On. ( Default )
# 1 ; Off. ( Shift light indicator will be turned off.)
Torque Management : Four levels,
#0 ; Stock.
#1 ; “Mild”. ( Default )
#2 ; “Moderate”.
# 3 ; “Wild” TM increase
Guys, I posted this question in another thread, so please accept my apology for the redundancy, but I got to know.
Those with an auto, when you have the (R) tune loaded, does the truck hold the gear until 4k rpms and then shift on its own at 4k, or are you manually shifting it to get it to 4k?
We will see how SW 9 works Because i'm getting a stg 3 cp3 very soon from John. My truck right know can take the rail pressure down to 5-6k
at WOT. I'm not lieing. It sounds like poop when it goes that low so I have been playing with SW 5,7 and it is much better. Jesse how does your react??
we want to get all beta tester(current) up to date with the revo53 revision so we can compare numbers with one software release.
I will be working on this as time allows. I would rather do this sooner than later.
more later
more later
Without checking I don't know which one I got. Do you know Bob?
revo5.3 is working for me!!! It might be a while before I can hit the dyno, but the truck is running good now... thanks to all who helped!!
I have version 4.13. Looks like I need a update.
