Will I make it
Old Jun 6, 2009 | 08:52 PM
OldSmokey's Avatar
Will I make it
What are my chances of hitting 650ish hp. HE 351 over BHT3B with 40 mm gate, Smarty beta 4.3, Quad X2 pressure only, Flux 1.8s, and stock pump with modded FCA and pump gear. Ive been told that I should be close to my goal as my stock pump has no problem keeping 26k for rail pressure. I will be on a mustang with 35s, I may have to big of a goal, what do you guys think?
Joel
Old Jun 6, 2009 | 09:54 PM
madhat's Avatar
Administrator/Jarhead
Hmmm... you might need more fuel. I'm at 636 with my mods.
I can't tell you too much about the mustang dynos... I think that they read different.
Old Jun 6, 2009 | 09:59 PM
OldSmokey's Avatar
Yah, Im kinda thinking I might be, but I just read about a guy with twin pumps, twins and 50 hp stix go 698 or something. The only way that I have been able to pull my rail pressure off 26 is if i use a TST, but it doesnt seem to make that much more power
Old Jun 6, 2009 | 10:02 PM
madhat's Avatar
Cheat a little and build some boost before he hits the switch. Hold the brake down a little until you see your boost rise (kinda like power brakeing it), when he says go, let off and stand on the go.
I think that I would have done a lot better if I would have had the TNT.
Old Jun 6, 2009 | 10:06 PM
OldSmokey's Avatar
I have TNT/R but ive read that 4.3 is stronger on 03-04. Your 636 was with the Revo SW?
Old Jun 6, 2009 | 10:09 PM
madhat's Avatar
Yes. I was a little smokey, probably could have used more air. I did not have time to play around with the settings, so I was wide open every time. (3 pulls)
I need to get some dyno time when I get back to fool around with it.
Old Jun 6, 2009 | 10:19 PM
OldSmokey's Avatar
Mine cleans up really well. Just a slight haze once the primary lights. I just threw in some studs today, so I only ran revo on 7 or 4.3 on 5.
Old Jun 7, 2009 | 12:12 AM
JJPage's Avatar
If you have an Auto, your sig does not tell, the minute you touch your brake pedal, your TC will unlock.
Besides, you do not want to cheat.... you are probably a good solid 600hp with what you have, not bad!
Old Jun 7, 2009 | 01:29 AM
OldSmokey's Avatar
Ive got a manual so that should be no problem.
Old Jun 7, 2009 | 01:37 AM
JJPage's Avatar
So.... you gonna cheat?
Old Jun 7, 2009 | 01:48 AM
OldSmokey's Avatar
They can usually get a pretty good load on a truck without it, and my twins spool pretty quick with the little 351 on top. I may have to try it both ways and see what happens
Old Jun 7, 2009 | 01:56 AM
JJPage's Avatar
If you have an S-04, I can send you the beta 4.2, it is the closest in hp to the TNT for the 03/04 trucks.
I dynoed the 4.2, it was only 13 hp higher than the 411(still under 600hp), but so hot and smokey, it was not a dd. TNT on 03/04 trucks is disastorous, the way it pops and bucks, something is going to break.
Old Jun 7, 2009 | 02:01 AM
OldSmokey's Avatar
I have all the programs, mine seems to run the best with 4.3. The TNT/R tune is pretty close, and doesnt have the poping that the TNT does. I havent had a chance to do any testing with the higher settings, yet. I finally got around to installing studs today.
Thanks for the offer
Old Jun 7, 2009 | 09:20 AM
homewrecker's Avatar
Mustang dyno's can be a little stingy on the #'s.There are so many variables that the dyno operator has so they will have to be very familiar with diesels and how to get a proper load on the motor to return a good #. Most people seem to think that Mustang #'s will be 5-15% lower than what a Dynojet will net.
Old Jun 7, 2009 | 09:47 AM
mikmaze's Avatar
a lot has to do with the options you select as well, tp tm timing.......
Bobp
Mar 14, 2003 05:52 AM
Mopar_Mudder
Dec 10, 2002 10:59 AM
rattle_rattle
Nov 6, 2002 02:47 PM
Redleg
Oct 16, 2002 06:44 PM
