Help! Too many decisions to make!
Old Nov 5, 2002 | 06:19 PM
rattle_rattle's Avatar
I'm having a heck of a time here trying to decide what to do with upgrades. The funds are going to be available in about 2 weeks and I want to have everything lined up as to what I want to get.
First is gauges. It either going to be a Rod Pod or a pillar mount. I like the Autometer Ultralight series. Should I wait for Rod? The three gauges I want are egt, boost and fuel pressure. My plans are for one of the three Edge boxes. Do I need the 60 PSI or the 30 PSI boost gauge? Does anyone have a part number for the ultralight fuel pressure gauge? Should it be a 0-15 PSI? I have the pyro figured out. Should I get the banjo bolts with the port?
I think I'm going for the Banks Monster Exhaust 4" stainless system. This decision is based only on the price. It's the lowest priced stainless system I've seen. At the same time, I think the Pac-brake is next in line.
Now for the boxes. It's a new truck. I would like to maintain warranty status (I know, "I'm my own warranty station&quot. Of the three Edge boxes, as I understand it, the Edge EZ is the easiest to remove when going in for warranty service. After I get over $500, the price difference for the three different choices make little difference. [undecided] I want some flexibility. The comp seems to give the most of that but what about removing it for warranty work? Is the Edge EZ Pulse just an upgrade of the Edge EZ with more options? Is it as easy to remove as the Edge EZ?
The idea of injectors crosses my mind from time to time but I think I'll see how my craving go for power after all of the above is done.
I need all the help I can get here. I'm going to be doing all the installations myself. On the mechanically inclined scale, I'm about an 8 on the 1-10 scale. I'm an electrical engineer by profession, so electronics and wiring aren't a problem. I would appreciate all the help I can get. The best teacher is experience and THAT is what is the best part about this site.
Old Nov 5, 2002 | 07:21 PM
BFC's Avatar
BFC
Re:Help! Too many decisions to make!
If I was you, I'd buy the Edge Comp for the box. Not much more $$ and if you don't tap the wire you get the same power as with the EZ. When your ready for more power, hook up that puppy and presto 80/90 more HP. You will be your own warranty station soon.<br><br>Keep in mind that Box+injectors(if over 2's)= clutch upgrade too!<br><br>Glenn
Old Nov 5, 2002 | 07:27 PM
chuck3's Avatar
Ditto the above. ;D
Old Nov 5, 2002 | 08:35 PM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=rattle_rattle link=board=7;threadid=6658;start=0#62566 date=1036541943]<br>Do I need the 60 PSI or the 30 PSI boost gauge? Does anyone have a part number for the ultralight fuel pressure gauge? Should it be a 0-15 PSI? I have the pyro figured out. Should I get the banjo bolts with the port?<br>[/quote]<br><br>60 PSI boost. 30 PSI fuel pressure. I'd heavily recommend higher flowing banjos, and if you've got a 2000 and up (sorry, didn't look at your sig), you'll need one tapped for a fuel pressure gauge.<br><br>[quote author=rattle_rattle link=board=7;threadid=6658;start=0#62566 date=1036541943]<br>flexibility. The comp seems to give the most of that but what about removing it for warranty work? Is the Edge EZ Pulse just an upgrade of the Edge EZ with more options? Is it as easy to remove as the Edge EZ?<br>[/quote]<br><br>Non-issue here. Unless you can find a Pulse that someone has in stock, they have been discontinued.<br><br>Rod
Old Nov 6, 2002 | 12:34 PM
TPilaske's Avatar
LMAO... I haven't even got my DDII's installed yet, and I am wondering if I should go bigger.... I just want a good setup to tow with! ;D <br><br>Tony
Old Nov 6, 2002 | 02:26 PM
hellotbone's Avatar
I have a comp forsale that fits the 2002 its used for this summer has 10,000 km/h on it I don't want a whole lot for it make me an offer. Jamie<br>Mouldings@ACI.ON.CA
Old Nov 6, 2002 | 02:47 PM
TxDieselKid's Avatar
You might want to look at the whole lift pump issue. Rather you want a &quot;pusher&quot; pump, or one that will take out the whole stock lift pump, and mount by the tank. <br><br>Andrew
TrkEnvy
Jul 30, 2007 05:14 PM
justagoodolboy
Jan 25, 2007 04:40 PM
TomW
Oct 13, 2006 07:40 PM
DRam11
Aug 17, 2006 03:08 PM
Eskimo
Jul 25, 2004 08:37 PM
