Will edge juice attitude give u 180 HP?
Mine is accurate up to 41psi which is the max it reads due to the limits of the stock sensor.
I hear that 41 a lot but I can even put on my smoke switch and it says 35. That is after the sensor so it must be my Edge reading goofy. I guess I will call them today and see if there is a newer version of software for it.
Ive had my Juice monitor up to 48 PSI and its dead on with my BD X-Mon which uses a boost bolt on the intake.
My edge pyro is the one that is off. Ive compared it to my BD-X Mon in the same location and its off by 30-35 degres at room temp (Double checked via IR temp gun). I cant accuratlly check it at the normal operating range other than a comparison to the BD X-Mon under simular driving conditions. But by doing so i guesstimate the Edge Pyro is off by 100 degres +- .
I know I have to set the cool down timer way lower to be sure it does what its supposed to. I went round and round w/Edge a while back and they basiclly said i was dumb and didnt know what i was talking about. They said they "use a $5000.00 calibrater on there thermo coupler" so it has to be right. I told them i dont care how much it cost if its off its off. Edge said they are not suppposed to be accurate until over 500 deg.
Yeah... that's the next mod... 8k, I'm goin all the way!
Walbro 392. Richard Martin, Glacier Diesel Power.
I have both, and I look at the mechanical guages more than I trust the edge.
Not saying anything other than what I just typed, so don't try to read between the lines...
Hope this makes sense
Tom
Well, what they said makes perfect sense. Most thermocouples have a temperature range that they are accurate for (calibration range). So it is entirely plausible that a thermo couple, that is engineered to read extremely high temperatures (probably > 2000 F), would not be accurate at low or near ambient temps. After all, why would it need to measure those low temperatures accurately, especially since EGT temps < 300 or 400 are of no use. There are thermocouples that are more accurate for a wider temperature range, but would be very expensive, and drive up the cost of the Juice w attitude package. Would you rather pay $50 or $100 more to get more accurate low temp readings?
Tom
Tom
Yes i agree with you, but useing the BD therocoupler and X-Mon under the same conditions (eng load, rpm, air temp etc) my EGT's read 100-150 degrees hotter than the edge. Simular to the 50 deg +- 10 in the 300 range. I just dont trust the Edge reading. But i use it for the backdown settings and the cooldown timer features. I will soon reinstall the X-Mon pyro pre turbo and move the Edge to post turbo.
Only because an infared temp gun was the same at the BD. This was only on the low end. But when i first turn key on in truck the BD pyro, tranns, eng, overhead and infa red all read exact same temp. The edge is the only one off by 30*............Could be better at normal range 700-1300* dont know. Just seems to be reading different than BD given same variables.
98rambaby
Sep 28, 2010 02:11 PM
sallyman1
Mar 16, 2010 03:47 PM
5.0 Mustang Man
Oct 21, 2008 02:50 PM
sallyman1
Dec 4, 2007 01:06 PM
razor6
22
Jan 20, 2006 03:43 PM
