Will edge juice attitude give u 180 HP?
Old Jan 8, 2008 | 09:00 PM
sallyman1's Avatar
I have a 2004.4 ram diesel. I am in process of waiting for my edge juice attitude with hot unlock. If i set attitude to HOT unlock and run a intake like ****** whistler and delete cat and stock muffler, will i see 500 engine HP over the stock 325 HP?
Old Jan 8, 2008 | 09:05 PM
Spooler's Avatar
Very doubtful...... Probably be in the 380-400 range.
Old Jan 8, 2008 | 09:06 PM
BlackSunShyne's Avatar
With just the J/A (hot) and an intake mod? Nope, at least not at the rear tires.
soulezoo's Avatar
DTR 1st Sergeant
Originally Posted by Spooler
Very doubtful......
X2....,....
Old Jan 8, 2008 | 09:07 PM
sallyman1's Avatar
i dont mean rear tires. and nether does edge. It just means 180 HP over stock 325 right?>
rip 112's Avatar
You won't have enough fuel...
Old Jan 8, 2008 | 09:08 PM
Totallyrad's Avatar
You have to remember one thing about that 325 rating, it's at the crank, not the rear tires. The Juice will most likely give you the 180 at the tires but you'll still be a little short.
Old Jan 8, 2008 | 09:12 PM
omaharam's Avatar
Don't go by crank HP. Your truck stock will dyno between 260-275 at the wheels. With the Hot Juice you will be looking at 430-450 at the wheels.
Old Jan 8, 2008 | 09:13 PM
sallyman1's Avatar
thats what i mean. i know 325 is at the crank. and edge boasts that hot unlock will raise crank HP up 180. So 325 + 180 =505 Crank HP. either way you look at it i will be gaining 180 HP right. so if my rwhp now is 250 it will go up to 430 rwhp. right?
And why wouldnt i have enough fuel. the edge will give me more fuel thats what it does.
Old Jan 8, 2008 | 09:19 PM
Spooler's Avatar
Need a new LP, Exhaust, and tranny you will probably see 430Hp at the wheels. Look at MadHat's numbers you will be close to that. He has an MP-8 where you will not.
Old Jan 8, 2008 | 09:20 PM
froggy69's Avatar
it does add fuel but, if it is asking for more fuel than your stock system can deliver then you will end up draining the rail and not making the power that you should
Old Jan 8, 2008 | 09:23 PM
sallyman1's Avatar
i will have exhaust ill have 4 inch str8 pipe with a aero4040xl in their. no cat no muffler. whats a mp-8?
Old Jan 8, 2008 | 09:25 PM
rip 112's Avatar
As said ^^^, you will not have enough fuel supplied from the stock pump to generate that power for long.
Old Jan 8, 2008 | 09:27 PM
Spooler's Avatar
MP-8 is a pressure box by TST.
Old Jan 8, 2008 | 09:28 PM
06CTDforAU's Avatar
One of the most commonly used pressure boxes ever sold. Stacks great with just about anything as long as it doesn't add pressure. As for the fuel issue these guys are talking about...... they aren't saying you will need more fueling to make more power; they are saying you will need more fuel to support the Hot Juice. In other words, a new lift pump system like a Walbro, FASS, or AirDog setup.
